Mouse Droppings In Addition Ceiling Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 05-10-2018, 11:13 AM   #1
Rewards Points: 24
Mouse droppings in addition ceiling insulation
I finally cut open an access panel into the ceiling to our addition. We've heard animal sounds in the walls and ceiling in that area a while ago so I thought I'd see what was there. When I dropped the drywall rectangle down, it had lots of mouse poop, just on the one little area that I removed. So I'm guessing the rest of the ceiling is just as bad.
No moldy smell and everything looks pretty clean. I do see some tunneling where mice have been but not everywhere. I imagine their main living areas are out of sight.
(I've sense put some hardware cloth on some spots I've suspected they were getting into the house and haven't heard them since.)
I called an insulation contractor who came out and took a look. He said he would start by removing all the pink batting insulation and vacuuming up all the poop. He then would spray open cell foam under the rafters to R34. No more nice environment for the mice and much better insulation.
He wants $450 to remove the existing insulation and vacuuming. $1300 for spraying the foam.
I could also remove the insulation myself and put down more of the same and then add another layer going perpendicular to the rafters for better insulation. Probably cheaper that way, but I wouldn't look forward to that job. It's a small space, probably 4 feet from the rafter to the peak of the roof over it.
If I just upgrade the existing insulation I still have a nice place for mice to live. Unlikely that I will be able to kill off all of the mice in the house.
Should I go with the spray foam? Thanks!
roperman is offline   Reply With Quote
Old 05-10-2018, 11:45 AM   #2
Rewards Points: 352
Re: Mouse droppings in addition ceiling insulation
Solve the mouse problem first. You aren't having temperature problems.
I'm failing to understand how spray foam insulation under the rafters to R34 will solve the mouse invasion problem.
SeniorSitizen is offline   Reply With Quote
Old 05-10-2018, 12:37 PM   #3
Rewards Points: 24
Apparently mice don't nest in open cell spray foam, so that's what is attractive about that option. If I remove the pink stuff, they will no longer have that to nest in.
I think the mouse problem is solved. Unfortunately, there's a lot of mouse poop left behind that I want removed. Removing it will improve the air quality in the room below that ceiling. I can remove, clean up, and replace with fiberglass batting also which would be cheaper. But then if the mice come back, the entire problem repeats itself. Spray foam looks like a better option.
Old 05-10-2018, 01:31 PM   #4
Rewards Points: 352
Ask you insulation contractor if he will guarantee mice won't build nests of foam insulation.
Old 08-28-2018, 03:53 PM   #5
Rewards Points: 68
if you were not having temperature issues, then removing the insulation, cleanup, sealing (mice proofing every single orifice) and re-batting is the simplest option. going to foam route could also work so long as you ensure there are not entry points for mice left open inside the space.
mycorrado is offline   Reply With Quote
Tags
addition , ceiling , insulation , mice , pests
Removing ceiling drywall with partial blown in insulation Bshaf Drywall & Plaster 4 04-30-2017 10:59 AM
How do I handle insulation in ceiling project DIYSeeker Insulation 2 07-04-2016 04:13 PM
Ceiling insulation using polyiso board and FG batts ddsrph Insulation 9 01-07-2016 11:00 AM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 07:12 PM
