Monty Python "Stringettes" Version Of Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 12-19-2014, 02:19 AM   #1
Restoration professional
Rewards Points: 302
Monty Python "Stringettes" version of insulation
I have 2-foot-short lengths of r-19 fiberglass insulation with paper facing. I need to insulate some walls. Rather than buy more insulation, can I re-use? Do I re-attach the paper together, if so, what kind of tape or mechanical fasteners are needed and how long with they hold together?
halliwellc is offline   Reply With Quote
Old 12-19-2014, 07:59 AM   #2
Rewards Points: 1,916
That's fine if you have 2 X 6 walls.
It's no different then using batts.
Just staple the flanges to the side of the studs and over lap the paper where they meet.
Old 12-19-2014, 10:34 PM   #3
Registered User
Rewards Points: 526
If the work will be inspected, it may not pass as R-19 is compressed (to R-18) from 6-1/4" to fit modern framing (5-1/2") and many inspectors may not pass it. Side stapling produces air gaps at drywall/insulation interface where full contact is required without convective loops in cavity, pp.45-47; http://www.buildingscienceconsulting...Measure_Up.pdf
Gary
PS. If majority of paper is missing, add a vapor barrier/retarding paint on drywall to meet required local code value.ADA the drywall; http://www.buildingscience.com/docum...wall-approach/
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
