Moldy Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 11-02-2014, 01:36 PM   #1
Rewards Points: 134
Moldy Insulation?
Hello,
I pulled out the drywall behind a baseboard heater in the basement, and this is what it looks like. It doesn't look very good. What should I do with this?
Thanks for any info!
jeffdoesrepairs is offline   Reply With Quote
Old 11-02-2014, 04:30 PM   #2
Rewards Points: 1,900
It's all trash now.
As mentioned before your going to have to address waterproofing that wall from the outside
Windows on Wash (11-02-2014)
Old 11-02-2014, 09:07 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
+1 to Joe's comments.
Its all trash now. Remove, abate the mold, fix the waterproofing and be done.
Old 11-08-2014, 09:39 PM   #4
Rewards Points: 332
Send a message via Yahoo to curtd
When i hear basement i think of a room below grade and now am wondering why drywall was ever installed there is the first place ? In one rental place, rooms were below grade...after cleaning out the mold we actually had to run a dehumidifier 24/7 every day thru the whole year so mold didn't return
curtd is offline   Reply With Quote
Old 11-09-2014, 07:46 AM   #5
Rewards Points: 376
Right on track, and when I read the word basement I wonder why build such a headache at all in areas where leaking is even a remote possibility.
Existing blow in insulation vs new insulation - Keep or redo? Jaxx Insulation 9 01-17-2014 08:26 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
