Metal Door Bottom Seal - Insulation - DIY Chatroom Home Improvement Forum
Old 08-11-2017, 04:04 PM   #1
Rewards Points: 2
Would anyone know anything about a seal that can be applied to the bottom of a metal door? This one is a little different from what I've seen.
- Two exterior swinging garage doors - each 36" length. On the bottom there is a rectangle cavity for what I imagine some kind of epdm slab goes in it. the cavity is 1 5/8 inch width, 3/4 inch height, 36 inch length , from what I can tell there are no lips or kurfs.
I just watched a salamander run underneath it, unacceptable.
NoBeerNoFix is offline   Reply With Quote
Old 08-11-2017, 05:58 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Metal Door Bottom Seal
Google search for "Door Sweep"
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-11-2017, 08:28 PM   #3
Rewards Points: 320
These thresholds worked for several decades then someone decided it was too easy to find replaceable seals so a change must be made to make life more difficult. This is what my doors will get when new are needed.
Old 08-11-2017, 11:05 PM   #4
Rewards Points: 463
See if this one matches your needs.
https://www.americanlocksets.com/ngp...36-p-4355.html
XSleeper is offline   Reply With Quote
Metal roof over existing asphalt shingles? Angelique Roofing/Siding 1 11-10-2016 01:57 PM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 09:27 AM
Need to waterproof seal metal and brick tdeepness General DIY Discussions 0 08-02-2011 10:09 AM
Fernco wax free toilet seal question? masterblaster4 Plumbing 2 07-21-2011 10:56 AM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
