Metal Building Insul. ? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-27-2016, 10:52 PM   #1
Rewards Points: 22
metal building insul. ?
I plan to have a metal building put up to be used for a weekender house/cabin. If I have insulation blown in the attic joists do I still need some sort of insulation just under the metal roof? It will have a ridge vent system also.
momark is offline   Reply With Quote
Old 04-28-2016, 06:21 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 846
Re: metal building insul. ?
No.
At that point, the insulation/envelope is at the attic floor. Between the combination of a well ventilated attic and a nice tight envelope, you should be able to mitigate condensation potential on the roof surface.
Is the roof going over a solid deck or over a system of purlins/battens?
Be sure to air seal prior to installing the insulation and that should help it stay even warmer and keep the moisture from moving into the attic and possibly condensing on the roof.
Old 04-28-2016, 10:58 AM   #3
Rewards Points: 22
It will be over a system of purlins and battens. Thanks for the tips.
windows for metal building. Cheap but good viper Windows and Doors 1 01-14-2014 06:37 AM
metal sheathing DiegoJames Electrical 2 07-01-2013 06:59 AM
Metal Studs in Metal building with horizontal support 7SistersRanchTX Building & Construction 1 03-06-2012 05:56 PM
Building a Metal vine covered pergola. dakkon Building & Construction 0 03-04-2012 08:10 PM
Can I frame with wood on a building instead of metal studs EHouse Kitchen & Bath Remodeling 4 01-12-2011 10:19 PM
