Making A 1929 Cap Cod Efficient - Insulation - DIY Chatroom Home Improvement Forum
Old 02-18-2015, 03:52 PM   #1
Rewards Points: 42
Making a 1929 cap cod efficient
Hello DIYers.
Recently purchased a old 1929 foreclosed housed that needed a ton of work. I mean a ton of work and we are nearing completion.
My last project was getting the master bedroom ready. I want to reserve this space to show what I did to make the grand master suite a livable, heat retaining, sound deadened, environment.
I call it the grand master suite because the house originally had two bedrooms up stairs in the second upper half. We turned the second bedroom into the master closet, cut out a section of roof, added a 10x10 dormer for a new master bath, and raised the collar ties for more head room along with new electrical and plumbing. Thats just the tip of the ice burg.
I have a ton a pictures of the insulation job I did on the master bedroom, I am about 75% done and am headed up now to finish the job. I would like some feed back of the methods I implemented.
Stay tuned and thanks for reading folks.
borzym60 is offline   Reply With Quote
Old 02-18-2015, 04:51 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 972
Capes are always a SOB to get tight and efficient.
Looking forward to the pics.
Old 02-19-2015, 08:14 AM   #3
Rewards Points: 42
I am just about finished. It was a decent size job considering all the abestos that was packed in between the rafter.
When I started demoing, I discovered there was no vent channel against the roof sheathing and the insulation that was there, was frozen to the roof which told me I had condensation from a lack a ventilation.
I did my best with what I had to work with while keeping head room in mind. The rafters are 2x6 and i added 2x2s to get me to 7.5" deep. I wanted radiant barrier all around and wanted the room to be as sealed as I could get it.
Ill let the picture explain the rest.
This was my starting canvas after some demo
Collar ties removed
Old fiber glass insulation behind the knee wall right up against the sheathing
The damp spots are melted frost from removing the fiberglass insulation
All cleaned up with raised collar ties in place and 2x2 furring in
7/8" MDF used to space for vent channel
1/2" aluminum rigid foam nailed to MDF vent channels
Space of vent channel
Sealing everything up
Getting ready to attach rigid foam to back side of knee wall to work as a thermal bridge preventative. Have to glue first for a better seal.
Old 02-19-2015, 08:14 AM   #4
Rewards Points: 42
Roof vent channel and knee walls all sealed up
Forward exterior wall sealed up
Adding r19 to rafters and r13 to 2x4 walls
And the final product with rigid foam used on all was to work as a thermal bridge preventive and thermal barrier. I am considering adding some more furring to the back side of all double foamed walls to give an air pocket so the radiant barrier is more effective.
How does it look?
Old 02-19-2015, 02:25 PM   #5
Rewards Points: 972
Interesting below deck vent.
Looks pretty tidy.
I am a bit concerned about a few things. Constructive criticism only.
1. Stacked vapor retarder levels. Between the foam, the faced batt, and the interior layer, there are several layers and you have limited the walls ability to dry in either direction. How is the first foamed faced. Perm rating on it
2. Vent space depth. Pretty tight and I would prefer to see 1.5-2".
The vapor point could be moot depending on the perm rate of the foam. Just my cursory observation looking at the pics on my small phone screen.
Old 02-20-2015, 11:49 AM   #6
Rewards Points: 42
Your right about the gap. I would prefer an 1" but I just couldn't afford the space to allow for it. My reasoning was anything would be better then what it was.
The walls are sealed from the interior so no heat/cool air can escape but they are opened internally to vent up through the ridge vent.
Time will tell I suppose?
The Following User Says Thank You to borzym60 For This Useful Post:
Windows on Wash (02-20-2015)
Old 02-20-2015, 01:39 PM   #7
Rewards Points: 972
This is true.
If you did a good job getting them air tight (outlets as well), the amount of moisture ever getting in there should be minimal.
Old 02-24-2015, 05:34 PM   #8
Rewards Points: 42
The differnce is amazing.
That ridig foam board will be apart of every insulating job I ever do in the future.
It makes the heat in the room so even with zero cold spots.
I can't believe the differnce. It's amazing.
It was -8 f last night and the exterior walls were not cool to the touch. Not like the rest of the house now with out the foam board.
Windows on Wash (02-25-2015)
Making an old fireplace insert more efficient Bed Rock HVAC 2 10-10-2012 05:39 PM
Honda pressure washer not making pressure brandon1023 Tools 1 07-23-2012 05:29 AM
Recommendations for covering conduit, and somehow making it look "natural" with tile. BigGuy01 Tiling, ceramics, marble 31 12-27-2011 04:57 PM
Making a melamine box secutanudu Carpentry 15 06-20-2011 02:51 PM
Making bear totum pole Keith of Ronin Landscaping & Lawn Care 2 03-27-2005 01:22 PM
