Kraft Faced Paired With Foam Board - Insulation - DIY Chatroom Home Improvement Forum
Old 01-14-2016, 10:25 AM   #1
Kraft faced paired with foam board
My house was built in 1912. The studs measure true 2x4". I live in iowa....a "cold" climate. I'm looking to completely fill in stud cavity with insulation. Can't find batting that measure 4" thick. Can only find 3 1/2x15" batting. Could I install a 1/2" foam board in stud cavity against outer sheeting sealing with foam sealant around perimeter and lay kraft faced fiberglass batting against foam board to accommodate the 4" needed? I'm confused on the vapor barrier rules as far as the do's and dont's. I am not looking to spray foam the cavities due to budget restricrions... Any help would be greatly appreciated. Thank you!
bniem77 is offline   Reply With Quote
Old 01-14-2016, 02:05 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 818
Vapor barrier recommendations are based on area.
https://energycode.pnl.gov/EnergyCodeReqs/?state=Iowa
What does the out sheeting consist of as well as the cladding (siding, stucco, etc.)?
Old 01-14-2016, 02:07 PM   #3
I believe the outside sheeting is 1x6 boards and the exterior is aluminum siding.
Old 01-14-2016, 04:34 PM   #4
Rewards Points: 818
If there is no housewrap on the home, I am sure there is a bunch of air streaming between those boards.
A small layer of foam, sealed to the studs, isn't a bad idea. You will need to research on what style and facing to put on the foam (if any) to make sure the wall can still dry out in one direction or another. Typically, you vapor control layer is on the warm side of the wall.
http://buildingscience.com/documents/digests/bsd-controlling-cold-weather-condensation-using-insulation
Installing deck ledger board over foam board? RickT Building & Construction 9 04-27-2018 11:41 AM
Foam Board Insulation issues zpotas Insulation 6 07-13-2017 01:32 AM
Can I Use Foam Board Beneath My Radiant Barrier On Rafters MorknMindy Insulation 4 02-14-2013 01:17 PM
Condensation On Foam board in basement tlh123 Building & Construction 1 02-12-2013 01:49 PM
Air Sealing Subfloor Joist Space - Foam Board? masonbrown Insulation 2 05-06-2012 03:54 PM
