Kneewall Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 10-28-2015, 06:41 PM   #1
Rewards Points: 763
Kneewall insulation
I'm located in the upstate area of South Carolina. I am finishing a Bonus room located over the garage. My question is knee wall insulation. My research indicates that I should seal off the backside of the knee wall with either OSB, drywall or solid foam board. The knee wall insulation will be fiberglass with a vapor barrier & applied between the knee wall studs.
My question is what R value should I be using for the knee wall. Right now I'm studded out with 2x4's which gives me R13-15. I think this is not enough insulation in what essentially is a "Exterior wall" if you think about it. I'm thinking I need to increase the studs to either a 2x6 for R19 or go to a 2x8 stud for R30. Because this bonus room is essentially built in the attic, I want to avoid issues with heat build up during the summer months, & a cool room in the winter. The room will be on its own heat pump system & separate from the rest of the house as far as heating & cooling system.
I've been thinking to just install R19 or R30 into the 2x4 studs of the knee wall & leave the backside open with no additional sheathing material since it will be inside the "Devil's Triangle" or attic space & I have no intention of using that area for anything. The bonus room floor is insulated with R30 between the garage ceiling & the underside of the bonus room floor.
Would appreciate hearing from some DIYer's & pros that have don this job & can tell me what I should consider doing down here in the sunny, hot & humid south.
maddog1 is offline   Reply With Quote
Old 10-28-2015, 08:33 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,022
Some foil faced Polyiso foam insulation would work great here. I would just make sure that you are doubling up your vapor barrier's in creating a vapor trap with your existing insulation.
The Following User Says Thank You to Windows on Wash For This Useful Post:
maddog1 (10-28-2015)
Old 10-28-2015, 09:02 PM   #3
Rewards Points: 763
Thanks- I've thought of foam, but its not in the budget & I need to keep this a true DIY project. The bonus room will not see very much use either, so with reasonably decent conventional insulation & the fact that the room has its very own heat pump system, it should be OK-not great, but ok for how I will be using the space. Thanks
Old 10-28-2015, 09:19 PM   #4
Property Mgt/Maint
Rewards Points: 26
pretty sure WOW means NOT to double up your VBs and create a vapor trap.
just one comment on the foil faced, if you use it behind the kneewall, you still should cover it with drywall to meet fire code.
[political signature removed]
Yodaman is offline   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
maddog1 (10-29-2015)
Old 10-28-2015, 09:55 PM   #5
Thanks Yoda.
Yes...left out the "not".
That's what I get for trying to type on an iPad with fat fingers.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
maddog1 (10-29-2015), Yodaman (10-29-2015)
Old 10-29-2015, 08:46 AM   #6
Rewards Points: 763
Thanks Yoda.
Hi- So lets say I insulate my knee wall with R13 or R19 fiberglass batts & also seal it off on the backside with ridged foam board-Unfaced, I need to cover that also with drywall? for code. Is that IRC code for residential building. Thanks
Old 10-29-2015, 09:52 AM   #7
Check with your local code enforcement. Is is best practice...yes.
The foil facing on many foam boards does qualify as the ignition barrier in many cases depending on the access of the space.
Old 10-29-2015, 11:23 AM   #8
Property Mgt/Maint
Rewards Points: 26
When I looked into a fire rated foam board about 1 yr ago (84 lumber) the cost was about 50 to 100% higher than regular foam board. And it was special order.
Not really sure why you would need anything on the back side other than the fiber glass. Its no different than loose fiberglass laying on attic floor. I would use a paper faced insul facing inside, add on the foam if you want the extra R-value, tape all the seams, then drywall over. If you want or need something on the back it should breath
Old 10-30-2015, 11:59 PM   #9
Registered User
Rewards Points: 526
Hot, humid climates require any vapor barrier/retarder on exterior of wall, including attic knee-walls; http://apps1.eere.energy.gov/buildin...rica/35793.pdf
ADA the drywall to stop the hot, moist air from reaching the cooler inside room; http://www.buildingscience.com/docum...wall-approach/
R-19 and R-30 are both low-density insulation, cover them both with housewrap, including the attic floor insulation. Use 2 layers of unfaced R-13 or attic side only-faced R-13 for a superior thermal barrier with no inherent convective loops and less attic wind-washing degrading the effectiveness.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Yodaman (10-31-2015)
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 10:04 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
blow in insulation question Cool user name Remodeling 4 12-30-2010 11:24 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
