Knee Wall Insulation - Attic Side - Insulation - DIY Chatroom Home Improvement Forum
Old 03-06-2018, 03:19 PM   #1
Rewards Points: 2
Hi all. I've searched but cannot find the answer to my specific question. I have a bonus room with 5' knee walls with R-19 insulation and want to increase the R value while air sealing the walls. Some sites say that I need to protect against radiant heat. I have sealed all outlets in the room so I'm ready to air seal the knee wall.
I believe there are 2 good options but I'm not sure which is best. Add 2" rigid foam board (R-10). Or add reflective bubble wrap (fixes radiant heat). The foam board is ~55% more expensive which I don't mind unless I will have the same performance with the cheaper option.
This site talks about using foam board but is geared towards snow bound states: Fine Home Building - Two Ways to Insulate Attic Kneewalls
jmooney5115 is offline   Reply With Quote
Old 03-22-2018, 11:21 AM   #2
vr4
Rewards Points: 12
Re: Knee Wall Insulation - Attic Side
The material costs here will probably be pretty trivial, especially for such a small space. My vote would be to go with the expensive stuff.
vr4 is offline   Reply With Quote
Attic knee wall and floor joist insulation daniel23111 Insulation 11 11-04-2015 09:21 PM
Advice for knee wall insulation Jake21 Insulation 2 02-12-2015 04:13 PM
Cape cod side attic insulation problems (fun) capecodfun Building & Construction 1 01-27-2011 01:49 PM
Converting Attic Knee Wall Space to Insulated Closet gigascott Building & Construction 7 01-20-2011 10:08 AM
Open channels down each side of bonus room gable end wall from attic? fdecker Building & Construction 4 11-17-2010 04:28 PM
