KC, MO- Partial Spray Foam Or Not On 820sq Ft Home - Insulation - DIY Chatroom Home Improvement Forum
Old 06-04-2017, 08:34 AM   #1
Rewards Points: 2
KC, MO- Partial spray foam or not on 820sq ft home
Hi,
This is my first time renovating and I am doing a complete renovation of a small 1908 home. I am trying to decide if partial foam spray is worth the expense on a house that is only 820 square feet. I was only considering foaming the bathroom and the wall the sun hits the most. Would this even be worth my time or should I just use batting all the way around?
nassachthal is offline   Reply With Quote
Old 06-05-2017, 09:44 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Re: KC, MO- Partial spray foam or not on 820sq ft home
Air sealing with proper batting will give you nearly all of the same benefit. What does the exterior of the home consist of (i.e. layers)?
Spray foam insulation troyce1 Insulation 12 12-14-2014 06:30 AM
Insulating in the attic with spray foam strategery Insulation 3 04-07-2013 11:46 PM
Spray Foam into walls behind kitchen cabinets? MovedTooMuch Insulation 4 09-21-2011 09:33 AM
Spray Foam Installation Problems Ron6519 Building & Construction 7 07-11-2011 01:50 PM
