Insulation Under Floating Building/in Freezing Weather - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By de-nagorg
Old 12-29-2017, 01:51 AM   #1
Rewards Points: 2
Insulation under floating building/in freezing weather
I am wanting to insulate under an old train car that is bounded by a wooden deck , lifiting it about 5 feet off the ground.
The bottom of the train car is composed of 4x6 wood beams. It is frozen and cold outside so i am curious what route would be cheapest/most efficient insulation on the bottom for the winter to keep the inside to hold extra heat, even if it is temporary. It is 26ft long x 8ft wide .
Alaska1992 is offline   Reply With Quote
Old 12-29-2017, 05:25 AM   #2
JUSTA MEMBER
Rewards Points: 98
Re: Insulation under floating building/in freezing weather
I would be skirting it similar to the way that mobile homes are skirted.
Using 2X 6, or 2X8 as the framework, with insulation between the studs, and sided with typical skirting material.
This seems to work well for those mobile homes.
ED
Gregsoldtruck79 likes this.
de-nagorg is online now   Reply With Quote
Old 12-29-2017, 12:16 PM   #3
Rewards Points: 1,060
Rigid foam panels glued/foamed to the bottom?
NotYerUncleBob2 is offline   Reply With Quote
Rigid Foam Insulation in Minnesota mattylance Insulation 2 09-24-2016 06:33 AM
Torn insulation in attic/knee wall Marky82 Insulation 15 09-06-2016 09:23 PM
insulation of basement floating floor menachem Insulation 3 01-26-2013 10:24 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
