Insulation Type? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-25-2017, 05:21 PM   #1
Insulation Type?
Hello all! just bought a house about 4 months ago, just crawled up into the attic about 10 minutes ago to see what the insulation situation was looking like. Does anyone know what type of insulation this may be? It's a very hard material and almost looks /feels like concrete. Is it safe to go over it with the new insulation?
Looking forward to your response!
Thank you!
Finessed is offline   Reply With Quote
Old 04-25-2017, 07:30 PM   #2
Rewards Points: 222
Re: Insulation Type?
Hi Finessed and welcome to the forum.
Only thing that comes to mind is what I've heard called a double plastered wall, in this case a ceiling. Does the house have lathe and plaster on the ceiling? If so I'm guessing they went into the attic and added more plaster from the top.
Now, old plaster can contain asbestos so you may want to have it tested before you do any demo or sanding. If left undisturbed it should be fine and adding more insulation above it should not be a problem.
Bud
Bud9051 is offline   Reply With Quote
Old 04-25-2017, 10:02 PM   #3
Hey Bud.
Thanks for the welcome and the quick response.
I know the walls are lath and plaster, I am not positive about the ceilings but I'm guessing so. I'll take your advice and apply the new insulation over it so I don't disturb what could be asbestos.
Thanks again!
Old 04-26-2017, 02:54 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Some of the shiny bits might be vermiculite, but not all vermiculite was ACM.
You can get it tested (not expensive) to be certain.
Be sure to air seal prior to insulating.
Old 04-26-2017, 07:09 PM   #5
Registered User
Rewards Points: 526
---------------------------welcome to the forums!-----------------------------
I don't see any value adding plaster to the top of your insulation as pictured. Looks to me like someone was painting up there and dripped on the floor boards and joists... may be cellulose- it crusts over from repeated wet/dry cycles in the attic.... 7th photo down....not vermiculite insulation; last photo;http://inspectapedia.com/insulation/...tion-Guide.php
Pick the spill up (if localized) and examine it and send us a closer picture. May be very old fiberglass blown-in instead... all flattened out (from its own weight- probably installed level with the joist tops originally- SOP back then.
Gary
Old 04-26-2017, 08:07 PM   #6
Rewards Points: 1,902
#1, No location in your profile,
I'm not seeing any real insulation in that picture.
This should have been noted in the home inspection!
https://www.energystar.gov/index.cfm...sulation_table
Best type of insulation for bathroom? TrailerParadise Insulation 1 01-09-2013 05:49 PM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Which type of insulation? diyer22 Insulation 7 10-02-2011 05:38 PM
Insulation type needed if using RedGard waterproofing? bigphil Insulation 4 09-29-2011 01:02 PM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
