Insulation In Soffit - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-16-2016, 05:52 PM   #16
Rewards Points: 142
Re: Insulation in soffit
Ah, got it now. So you're looking to just remove the insulation in the soffit bay that has the vent? Yep, that one shouldn't be blocked with insulation. You could probably leave some of the insulation in the rest of them that aren't vented. You don't want to take away insulation except where it's blocking the airflow to vent the roof.
My guess is that it's not coming out easily because the paper backing (vapor barrier) is attached to the rafter tails. Faced bats are typically stapled to hold them in place. If it is, then it definitely needs to come out too since just pulling the pink fiberglass part without removing the paper will still block the vent.
You could try reaching in there with a utility knife and lightly slicing along the edge of the rafter tail to cut the paper facing. Be careful reaching in there though...not much holding that soffit vent in place and you don't want to push it out.
SPG43 is offline   Reply With Quote
Old 10-16-2016, 09:19 PM   #17
Rewards Points: 2
I can even get back there to try to cut it. My husband and I have tried. We even tried a tree cutter and that didn't work.
jenzee1 is offline   Reply With Quote
Old 10-17-2016, 01:16 AM   #18
Rewards Points: 142
yep, not the easiest place to get into. You'd have to put some planks across the ceiling joists and belly crawl in there! Not fun and you really have to be careful to not come through the ceiling, but then the alternative is to get there from the outside on a ladder if you can remove those vent panels from the outside without damaging them. Pick your poison or call in a contractor.
Old 10-17-2016, 09:43 AM   #19
Rewards Points: 1,528
maybe try one of these on a pipe or stick... the challenge is the way the fiber run... but if you can get something like this in there and compress it sideways. maybe you can get it out?
ryansdiydad is offline   Reply With Quote
Soffit upgrade and insulation clearance eelpout Roofing/Siding 1 07-14-2013 09:23 AM
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 10:04 AM
Removing Insulation from Soffit Vents cpfoutz Roofing/Siding 18 01-03-2012 09:35 AM
Attic Insulation tim1218 Insulation 4 09-07-2011 10:18 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
