Insulation Needs - Insulation - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 03-22-2019, 01:20 PM   #31
Rewards Points: 222
Re: Insulation needs
Originally Posted by Nealtw View Post
The R-value of anything only counts if the space is full and fit good, I think most people find rock wool better as it is harder to cheat than with fibreglass. So mostly it is just a matter of craftsmanship.
I think Bud's point was adding the foam and 1x2 or 1x3 has very little benefit over just adding a 2x2.
I have never worked with rock wool before---when I looked on the website that has it for sale and where I planning on buying it, it lists as 5.5" thick. Was thinking--a 2x4 is 3.5 inches plus the 1" foam plus the 1x3 of .75", that only adds to 5.25".
So, is rock wool "squishy" enough to fit my space given that it is only 5.25" and not the 5.5" thickness that the rock wool comes as?
jsmith1107 is offline   Reply With Quote
Old 03-22-2019, 01:30 PM   #32
retired framer
Rewards Points: 750
I am not sure but I think you end up with the R value of the 5.25 which would be the same as if you could buy a 5.25 thickness.
But you could go the thicker foam strip.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 03-22-2019, 01:59 PM   #33
Rewards Points: 226
Sorry, you did 3/4 foam on the inside or outside? Can you explain what you mean by doing a flash and fill with closed cell foam followed by fiberglass?
I am buying my insulation at Menards--that's where I got the pricing on it.
we did 3/4 foam on the outside.
see link below for flash and fill, basically flash 2" or so of spray foam, then fill the rest of teh space with fiberglass
https://www.buildingscience.com/docu...l-construction
FYI, mineral wool comes in 3.5" deep too.
I see the pricing at Mernards, makes sense, its for less coverage than I was getting per pack.
Spyder is offline   Reply With Quote
Old 03-22-2019, 02:41 PM   #34
Rewards Points: 214
You could buy 1.5" rigid and cut 1.25" strips so the 3/4 would bring you out to the 5.5" depth to match the 5.5" mineral wool.
As for fitting the 5.5" batts into a 5.25" space very easy, they come all squished in that bundle. The difference in r-value would be 5.25 divided by 5.5 or 95% of rated value. If that rated value is r-23 then you end up with r-22.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 03-22-2019, 04:12 PM   #35
Rewards Points: 222
Thanks a lot---I will do that I think.
Would it hurt if I put 1.5" foam behind and then I would have like a 1/4" gap? Does the gap hurt anything?
Old 03-22-2019, 05:10 PM   #36
Rewards Points: 214
Personally I would avoid the gap if possible, but doubt it would make any difference.
Bud
Old 03-28-2019, 01:32 PM   #37
Rewards Points: 370
Originally Posted by Bud9051 View Post
For caulking I use the large tubes of construction adhesive. Less expensive and will last forever.
Bud
Construction adhesive can be used instead of caulk?
I never considered that ...
Is it done often, do they have different colors like caulk?
Is it used around windows too?
DallasCowboys is offline   Reply With Quote
Old 03-28-2019, 02:49 PM   #38
Rewards Points: 214
I use it strictly in the framing areas. If it will be exposed then use a caulk which would give you color options and paitable. I'm just a penny pincher and usually have the construction adhesive around.
Bud
DallasCowboys likes this.
Insulation in attached garage below a living space Vgizzo Insulation 8 01-18-2019 08:47 AM
Help with Attic Insulation Vinyl Exterior easywolf32 Insulation 10 10-22-2018 03:41 PM
Basement Insulation Ontario CodeMatters Insulation 6 03-21-2018 09:14 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
