Insulation For Narrow Gap Wall? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Bud9051
  • 1 Post By Bud9051
Old 01-17-2018, 08:47 AM   #1
Rewards Points: 6
Insulation for narrow gap wall?
Howdy folks!
I live in a tiny house that was tacked together during the Great Depression.
The exterior walls feature an uninsulated gap that's about 2˝ inches.
Foam insulation contractors insist that foam won't spread properly in such a narrow gap.
Is anyone aware of a free-flowing loose fill insulation that won't eventually settle much or at all—that could be poured into a large hole drill up high?
Thanks!
DisasterMaster is offline   Reply With Quote
Old 01-17-2018, 08:54 AM   #2
Rewards Points: 114
Re: Insulation for narrow gap wall?
Hi Master,
What is on the inside and outside. If concrete or brick there are moisture concerns. And approximately where are you, heating or cooling climate, or both .
Bud
DisasterMaster likes this.
Bud9051 is online now   Reply With Quote
Old 01-17-2018, 10:57 AM   #3
Rewards Points: 6
Elmira Heights, NY
The outside is old Dutch lap siding covered with Masonite siding. UGH!
The inside is either old drywall coated with a thin layer of plaster, or 3/4" furring strips, with thin fiberglass insulation between, over the drywall/plaster—covered with paneling. UGH, again!
Old 01-17-2018, 12:50 PM   #4
Rewards Points: 114
Can I assume the 2.5" gap is available on all outside walls?
Electrical wiring should not be the old knob and tube with a 1930 vintage home so foam insulation should still be an option. But, have you talked to any contractors that install cellulose. A bit more work with the narrower gap (not the normal 3.5") but they should still be able to do it. The decision would have to be made as to blowing in from the inside or outside. This time of year I would vote for the inside. If that paneling could come off that area would be easy to cover, just put the paneling back up.
In terms of adding insulation to the smaller space it is always the first amount of insulation that yields the most savings. And blown-in cellulose will air seal. The contractors use a lot of it up here in Maine.
Make a few calls and get a quote or two and listen to what they are suggesting. If you can DIY, cellulose can be done.
Bud
As for pouring in an insulation they still make "perlite or vermiculite insulation" but I would expect some settling over time and its r-value is a bit lower.
Attic knee wall and floor joist insulation daniel23111 Insulation 11 11-04-2015 09:21 PM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Where to apply vapor barrier(s) for wall insulation patented Insulation 6 10-29-2012 11:17 PM
Exterior wall insulation iowa climate strategery Insulation 1 02-16-2012 02:34 PM
attic insulation / knee wall oscarMadison Building & Construction 2 01-19-2010 08:37 PM
