Insulation In Fridge Door - Insulation - DIY Chatroom Home Improvement Forum
Old 05-13-2020, 03:29 PM   #1
Rewards Points: 48
Insulation in Fridge door
An old but excellent fridge at my cottage has developed a rusted out area at the bottom front of the main door. Looks like humidity and condensation from the inside has rusted through.
The hole on the door is about 3 inches long and an inch wide. Quite a gap. Strangely enough, there seems to be no insulation in the bottom area of the door and I wonder if any in the door at all.
On humid warm days water drips out on the floor and the rust will only get worse.
How can I seal this gap and prevent more condensation? I picked up a can of low expanding spray foam but it says not to use it in cavities and voids. would it be waterproof in any case or just make the door worse?
I also see automobile bondo suggested. thanks for any help
CamperD is offline   Reply With Quote
Old 05-13-2020, 03:43 PM   #2
retired framer
Rewards Points: 568
Re: Insulation in Fridge door
Take the inside of the door off and fix the insulation problem. Just put some aluminum tape over the hole.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 05-13-2020, 04:48 PM   #3
Rewards Points: 48
taking the door apart is not an option, or at least a last ditch effort. I wanted to find a used door that would fit but with the covid-19 matter, I have not been out looking.
Like I said, the door never had insulation at the bottom in the first place. So if I want to seal the hole, what do you think would work best and be more moisture proof, in case. Low expanding spray foam or auto bondo? Once I fill the hole I will tape it over. Thanks!
Old 05-13-2020, 04:53 PM   #4
retired framer
Rewards Points: 568
Why is is removing the liner not an option, older ones had 50 screws and new ones are just stuck on and you can use double sided tape if they don't stick.
figure 7-14
Old 05-13-2020, 04:57 PM   #5
Rewards Points: 48
this is a 40 year old fridge.....beer fridge at camp....i just want to seal the bottom without it getting worse.
Old 05-13-2020, 05:00 PM   #6
retired framer
Rewards Points: 568
Just tape up all the holes so air can't get in there and all the dripping will be on the outside.
figure 7-14
Old 05-14-2020, 07:21 AM   #7
Rewards Points: 1,952
Just in case, don't use great foam or such that may expand too much and change the shape of the door. If you seal that hole, may create another rust spot since water will find another way.
carpdad is offline   Reply With Quote
Old 05-14-2020, 04:41 PM   #8
Rewards Points: 1,094
DO NOT use bondo that will be a waste of time . Moisture will go right through it . The suggestion of aluminum tape is a good one . Ultimately pulling the door off and disassemble so you can get in the door is best . I would add low expansion foam to the entire door cavity . Trim it if it expands too much and reassemble . Good for another 40 years
Porsche986S is offline   Reply With Quote
