Insulation For Dryer Exhaust Piping - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Colbyt
Old 11-21-2017, 07:25 AM   #1
Rewards Points: 8
Unhappy
Insulation for Dryer Exhaust Piping
First time home owner here,
Yesterday, while running the dryer, I noticed water dripping from the dryer exhaust piping in the basement. It is getting cold outside and my basement is not heated. My guess is that the hot air is condensing in the pipe (which runs through the basement false ceiling) and does not make it out of the side of the house in time.
After I removed the ceiling tiles I noticed that someone tried to patch up all the exhaust pipe connections with duct tape. Something tells me duct tape is not going to hold water....
I am guessing I need to insulate this exhaust duct for the dryer. Just wanted to make sure with you guys that I am thinking the right way. If yes, what kind of insulation do I need? This is probably a 3-4" diameter exhaust pipe.
StudFinder is offline   Reply With Quote
Old 11-21-2017, 07:33 AM   #2
Rewards Points: 26
Re: Insulation for Dryer Exhaust Piping
If I wanted to tape it, I would use the metallic foil tape doing the seams and joints.
You may be able to find a 4" duct sleeve else use fiberglass.
I personally would probably run PVC pipe for the duct and slope it to the outside.
Bud9051 likes this.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 11-21-2017, 09:51 AM   #3
Rewards Points: 8
Hmm.. I did not think about that - replacing with PVC. As I said, i am not experienced at this, but couple of google searches got some articles not recommending using PVC. Main points where heat damage over the years and static build up that attracts lint to the sides of the pipe.
Link to the video about PVC i watched:
I will check out to see if there any appropriately sized insulation sleeves i can buy.
Old 11-21-2017, 05:39 PM   #4
Rewards Points: 352
A filter installed in the dryer as factory recommended would have solved most of their pvc pipe lint problems.
Tags
dryer , duct , insulation
insulation in attic or crawlspace fordfocus1948 Insulation 7 04-20-2017 06:06 PM
Rigid Foam Insulation in Minnesota mattylance Insulation 2 09-24-2016 06:33 AM
Torn insulation in attic/knee wall Marky82 Insulation 15 09-06-2016 09:23 PM
Bath Exhaust Duct Insulation WoodmanFL HVAC 1 12-20-2011 12:29 PM
