Insulation Of Chilled Water Piping - Insulation - DIY Chatroom Home Improvement Forum
Old 02-05-2015, 05:09 PM   #1
Rewards Points: 4
insulation of chilled water piping
Good day pals;
Got this job to insulate chilled water piping with polyisocyanurate rigid foam. I have mastic available for the job, but need enligthment on the appropriate tape for securing the insulation. talking of pressure sensitive tape. can duct tape do the job?
thanks pals.
tnat is offline   Reply With Quote
Old 02-05-2015, 07:56 PM   #2
Rewards Points: 469
How can you wrap rigid foam around a water pipe ?
Jnaas2 is offline   Reply With Quote
Old 02-05-2015, 08:26 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 16
It is preformed for the pipe diameter
Old 02-09-2015, 09:19 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 844
What does the exterior of the foam consist of?
Old 02-09-2015, 12:16 PM   #5
Rewards Points: 4
Its made of embosed aluminium foil
Old 02-09-2015, 01:09 PM   #6
Rewards Points: 844
Before will duct tape should stick like a dream to that stuff.
Old 02-09-2015, 07:02 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I would think foil tape would be the appropriate type of tape.
I would never use duct tape for anything other than ducks (not ducts). It degrades quickly.
Old 02-09-2015, 09:43 PM   #8
Rewards Points: 844
Originally Posted by nap
I would think foil tape would be the appropriate type of tape. I would never use duct tape for anything other than ducks (not ducts). It degrades quickly.
Dictation error via phone from before.
I was recommend in "the foil" and the voice translation heard "before"
The Following User Says Thank You to Windows on Wash For This Useful Post:
nap (02-09-2015)
My hot water recirculation system is a disaster Michael Neill Plumbing 29 08-30-2019 06:15 PM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Choosing a new heating/cooling system Mattme123 HVAC 7 08-13-2012 03:43 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
