Insulation In Celing Of Bed Room Question - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bud9051
Old 07-18-2016, 05:59 PM   #1
Rewards Points: 76
insulation in celing of bed room question
hello i was repainting celing today in bed room after scraping some peeling paint and letting the joint compund dry a full day. today in ny it was abot 90 degrees and the celing of the bed room was hot not like hot that it would burn u but warmish i would sayw. my question is i have seen insulation in the atticon the floor which would be the celing of the bedrooms. but its old and very brittle like it would come apart when u touch it.my question is should that attic insulation be replaced? or should i just remove all insulation in attic. and leave it bare. i have a ridgevent and also theree roof vents plus gables. any information would be great
Sent from my SM-G900V using Tapatalk
charles3526 is offline   Reply With Quote
Old 07-18-2016, 06:15 PM   #2
Rewards Points: 98
Re: insulation in celing of bed room question
Some will remove the old ugly insulation, but never leave it empty. Either add a lot over the top or remove and then add a lot. Not sure of your climate requirements, but r-50 would be a good start.
As for the ventilation, soffits or other low positioned vents are necessary to create the air flow with the other high vents.
Bud
Windows on Wash likes this.
Bud9051 is online now   Reply With Quote
Attic room insulation question. Orrin Insulation 5 05-15-2017 06:27 AM
Another Rigid Insulation over Block Question jdon88 Building & Construction 1 02-16-2011 10:25 PM
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 07:54 PM
Insulation question Branden Building & Construction 1 08-03-2010 01:02 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
