Insulation Breathing - Insulation - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By Nealtw
  • 1 Post By fireguy
  • 1 Post By NotyeruncleBob
Old 10-29-2017, 12:01 AM   #1
Rewards Points: 8
Insulation breathing
Hey first time here. Forgive me if i placed this in wrong area this was the only active forums where I thought I could get an answer.
Anyway I recently placed my computer in the basement where we have a excess insulation sitting in. The basement is pretty big... thing is I didnt know that breathing in or near insulation is bad for you (I have no knowledge of those feilds). So for the last month I've been stupidly doing computer work down there for a few hours a day... the insulation sits about 20 feet away from where my pc was (I've obviously moved now) how screwed am I? I have no symptoms of anything but I've read how it can stick to your lungs and cause cancer and show no symptoms for 10-30years. Most days I probs spent just over an hour in there. In weekends would be more.
Should I be worried? I feel fine but now I'm paranoid. I wish they taught this sort of stuff in school.
Deathstroke is offline   Reply With Quote
Old 10-29-2017, 12:07 AM   #2
retired framer
Rewards Points: 838
Re: Insulation breathing
You read to many scary books.
If you are not touching and causing any dust from it to get in the air it is fine.
Bondo and Bud9051 like this.
Nealtw is offline   Reply With Quote
Old 10-29-2017, 12:08 AM   #3
jlhaslip's Avatar
Rewards Points: 708
Would only be an issue if the insulation was being disturbed or moved.
Can you see the dust particles moving around in the air? If so, you need to get to the Dr and get a chest x-ray, maybe.
Can the insulation be covered with poly? That would minimize the particulates.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-29-2017, 12:18 AM   #4
Rewards Points: 8
Yeah I didn't see any particles. Also haven't touched it or moved it. I always had the door open when I was down there too. Just worried because a month down there a few hours everyday cant be good. It wasnt until a family member recently told me about the hazards of insulation that I realised how stupid I was. So you guys think I'll fine?
Also thanks for the quick and helpful replys =)
Old 10-29-2017, 12:35 AM   #5
Rewards Points: 8
Here's a photo of exactly what's sitting there
Old 10-29-2017, 12:40 AM   #6
Rewards Points: 8
O it didnt upload for some reason. Here it is in link anyway https://imgur.com/dY6jxEU
Old 10-29-2017, 01:01 AM   #7
retired framer
Rewards Points: 838
There would be no reason for anything to move. It would be the guy that worked with it for years that I would worry about.
Old 10-29-2017, 01:07 AM   #8
Rewards Points: 20
I was in another attic today, looking at fire sprinkler piping. We often disturb the fiberglass batts, the blown in ground-up news papers, the rock wool, and whatever other insulation may be in the attic. To date, I am still alive and as far as I know, am not eligible for any of the current scare tactics by the lawyers who advertise on TV.
But if you are really concerned, get some dust masks at the hardware store.
Nealtw likes this.
fireguy is offline   Reply With Quote
Old 10-29-2017, 05:24 AM   #9
Naildriver
chandler48's Avatar
Rewards Points: 374
Off topic somewhat, but you will need to deal with those open vent blocks before you do any remodeling. Where are you located? I'd be more concerned with outside air and contaminates (not really) than I would a dormant stack of insulation. You could always bag it up or cover it.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 10-29-2017, 12:33 PM   #10
Rewards Points: 1,066
You're fine.
...and this is coming from the person who has to remind people around here about the dangers of many exposures.
In case you're still worried... Fiberglass is more of an irritant than a carcinogen, meaning it's more uncomfortable than hazardous. You also need to be disturbing the insulation enough to get fibers loose and in the air. You also need to be close enough to inhale them. You also need to be in enough of an enclosed space that any fibers wouldn't be able to dissipate or settle before they reached you. You were far enough away from undisturbed fiberglass batts in a large enough space that your exposure was essentially zero. If your scenario was hazardous then every cashier at Home Depot would be dead by now.
Nealtw likes this.
NotyeruncleBob is offline   Reply With Quote
Old 10-29-2017, 10:52 PM   #11
Rewards Points: 20
Originally Posted by NotyeruncleBob View Post
You're fine.
Now we know why the large turnover in HD employees
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
