Insulation Benefits? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-29-2015, 07:29 AM   #1
Rewards Points: 439
insulation benefits?
I live in the midwest where the temps get very cold in the winter......
In my garage, I have finished walls but there was never insulation installed when the home was built in 1992.
I know insulation helps, but if i were to place insulation in the walls, how much warmer would it actually be in the winter? I do not have heat in the garage except for any portable heater i use.
would there be a noticeable difference in temperature? Is this worth doing?
crankbait09 is offline   Reply With Quote
Old 10-29-2015, 07:41 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,924
Your best bang for the buck would be the ceiling. That is where a majority of your heat loss is from. The effort to insulate the finished walls is most likely not worth it unless you spend a lot of time out there.
But, it is worth insulating the garage door and sealing any leaks. that is money well spent.
ddawg16 is online now   Reply With Quote
Old 10-29-2015, 07:44 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 812
Ceiling will slow the rate of heat loss through the upper plane.
Insulating the doors will help as well. If you are assured there is nothing in the walls, you can cut and retrofit blow in as well.
ddawg16 is right in that it will be the ceiling that is easiest and largest surface that would get done first.
Old 10-29-2015, 07:48 AM   #4
Rewards Points: 439
the garage definitely has insulation in the ceiling. The crawl space access hatch is in the ceiling in the garage, so thats covered
my garage door is insulated as well
Old 10-31-2015, 12:44 AM   #5
Registered User
Rewards Points: 526
Lose more heat out the walls; http://www.explainthatstuff.com/heatinsulation.html
The walls lose heat through conduction (thermal bridging of studs); convection- convective loops in open cavities running when heater is active, and windows by radiation.
If walls are 9' tall times 3, times 22' long, by 10' wide; 486 sq.ft. rather than 220 sq.ft. ceiling is even worse. Better if double car garage size though you said door (singular)...
Adding different thicknesses of insulation reaches a cost/value after so much; compare no insulation to adding some, watch the relationship; http://www.buildings.com/article-det...g-returns.aspx
Gary
Old 10-31-2015, 07:47 AM   #6
Rewards Points: 439
Gary
just to clarify...my garage is a two car garage.....
The Following User Says Thank You to crankbait09 For This Useful Post:
Gary in WA (10-31-2015)
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
