Insulation Behind Wood Paneling W/out Drywall ? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By stick\shift
Old 05-22-2017, 03:55 PM   #1
Rewards Points: 140
Insulation Behind Wood Paneling w/out Drywall ?
I have furring strips attached directly to the wall in my basement workshop. I'm planning on putting up paneling - I'm not exactly sure what yet and will investigate options. I would prefer not to put drywall under the paneling ... My question - is there any kind of insulation (like foam board) that is rated for direct contact with concrete & wood panels ? Thank you
JohnyFever is offline   Reply With Quote
Old 05-22-2017, 04:04 PM   #2
Rewards Points: 4,864
Re: Insulation Behind Wood Paneling w/out Drywall ?
Foam board would be fine but would have done a better job if it went up before the furring strips, as they create a thermal bridge.
Bud9051 likes this.
stick\shift is offline   Reply With Quote
Old 05-22-2017, 04:17 PM   #3
Rewards Points: 140
Yes - I agree. When I took down the existing panels a few of the furring strips came down with it, but most of it was tight - so I did not want try pulling the rest down and start from scratch.
I thought I read somewhere that the pink foam board must have drywall or some other kind of fire barrier other than wood panels due to the toxicity of the foam board? I tried looking at my local building code but found nothing that addressed this. Thank you for the reply.
Old 05-22-2017, 04:28 PM   #4
Rewards Points: 222
3/4" pine might be sufficient but I don't have the reference. Your local code office would probably know.
Not sure of your location but many areas are now requiring more than just a thin layer of rigid foam. Here is the 09 listing.
https://energycode.pnl.gov/EnergyCodeReqs/
In addition, furring strips make it more difficult to get the wiring installed for outlets.
As always, resolve any moisture problems before you try to cover those walls.
Bud
Bud9051 is offline   Reply With Quote
Tags
basement , insulation , paneling
Replacing drywall after removal of wood panels kdtx Drywall & Plaster 6 01-10-2017 05:35 PM
Questions on floating/texturing wood paneling. *C-Ro* Remodeling 7 12-31-2014 10:33 AM
Covering Wood Paneling with drywall jusduky Drywall & Plaster 6 02-11-2014 12:08 PM
Can I put old removed wood paneling over joist in attic timmay_8 Building & Construction 6 12-15-2011 02:40 PM
Stucco over my cedar wood paneling vs stucco over newly installed plywood beesan Building & Construction 5 12-21-2009 12:24 PM
