Insulation Behind Shower Walls - Insulation - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By ktownskier
  • 2 Post By chandler48
Old 05-20-2020, 03:09 PM   #1
Rewards Points: 48
Insulation behind shower walls
Our house in SE Texas was built in 1960. I am about to remodel the standup shower (36"x36"), which will mean tearing out three ceramic tiled walls, two of which back up to an exterior brick veneered wall. I will be installing the new Hardibacker Hydro Defense cement board when I begin rebuilding the shower walls. The Hydro Defense is waterproof and does not require any type of waterproof membrane to be applied over the exposed surface.
When I recently tore out a ceramic tiled wall that is adjacent to the shower, which is also along an exterior wall, I discovered there was no insulation between the studs. I didn't think too much about it, but went ahead and installed new insulation anyway before putting up new greenboard. I have a feeling that when I tear out the shower walls, there will be no insulation there either.
So my question is this. Since we live in a warm climate year around do I really need to install insulation on the shower walls that face an exterior wall. Would it serve any purpose? Even though the Hardibacker is waterproof, I still plan to install a plastic vapor barrier maybe 3 feet up the wall studs just as a secondary defense.
Anyone have any thoughts on the need for insulation behind the shower walls, all things considered? Tks.
stardogFB is offline   Reply With Quote
Old 05-20-2020, 03:16 PM   #2
retired framer
Rewards Points: 924
Re: Insulation behind shower walls
If you run AC in the summer you might want it there.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
stardogFB (05-20-2020)
Old 05-20-2020, 03:22 PM   #3
Rewards Points: 4
I would suggest checking your local building codes to see what they have. Just because they didn't do it in the 60's, doesn't mean it isn't required today.
Regarding the new CBU from Hardie, you do have to seal the joints and any perforations. (Like screws and nails).
Joints and Penetrations
• Seal fixture penetrations, plumbing penetrations and abutments to dissimilar
materials with flexible sealant (see “Materials Required”).
• Fill all joints with mortar (see “Materials Required”). While mortar is still
workable, embed minimum 2 in. wide high-strength alkali-resistant glass
fiber tape in the mortar and level.
• Do not use all-purpose joint compound or paper tape.
• When complete waterproofing is required, seal all joints, edges and fastener
penetrations with a liquid waterproofing membrane. Follow the liquid
waterproofing membrane manufacturer application instructions.
I am planning on using Redguard as half of my wall is greenboard and the rest is the new Kerdiboard. And for the joints, I plan on using Kerdi Band. Better to be safe than sorry.
As for insulation, I was planning on using rockwool insulation as it is naturally moisture and mold resistant. Vermin also doesn't like it. Besides, why not insulate?
If you can, build a bigger shower, 36"x36" shower is kind of small. But if you can't, well, you were used to it before.
Dave Sal likes this.
The only stupid question is the one you DON'T ask!
ktownskier is offline   Reply With Quote
The Following User Says Thank You to ktownskier For This Useful Post:
Old 05-20-2020, 03:36 PM   #4
Rewards Points: 48
Thanks for the quick replies from both of you. Since we live in the Houston area I can pretty much guarantee the A/C is often on in the summer. I will go ahead an insulate, especially since its such a small area to cover anyway.
Regarding the Hydro Defense cement board, agree on covering all seams and penetrations before tiling, per manufacturer instructions. As far as the base, if I could go bigger I would. But I'm gaining a few more inches of floor space since I am replacing the current neo-angle configuration with 36" square base. You take what you can get.
Old 05-20-2020, 05:17 PM   #5
Naildriver
chandler48's Avatar
Rewards Points: 460
It's a good idea to insulate. Here, we gathered up 3 ea. 55 gallon drum liners of insulation that squirrels had pulled from the wall to make nests under the tub we removed
Then we go back in with Roxul. Waterproof, fireproof, vermin proof, mold proof and needs no vapor barrier.
Insulation behind shower walls-20190805_101901.jpg   Insulation behind shower walls-20190806_122245.jpg
Dave Sal and Nealtw like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
