Insulation Behind Fireplace - Insulation - DIY Chatroom Home Improvement Forum
Old 03-03-2016, 11:13 AM   #1
Rewards Points: 49
My sister just purchased a townhouse that has a large (12 foot) crawlspace under the living area. I was down there checking for leaks/dry rot/termite damage/etc. and I noticed that the insulation behind her fireplace (pellet) has been pulled out. There is about 4 inches behind the fireplace back wall and the studs. The insulation (3.5 inch R11) that is still there is blackened, but most has been pulled out and now it's just open framing behind the fireplace. I would like to replace the insulation, but I want to avoid the same problems.
What is the best insulation to use? Is a 4 inch gap between the back of the fireplace and the insulation sufficient?
Cultcab is offline   Reply With Quote
Old 03-03-2016, 03:42 PM   #2
Rewards Points: 1,902
Need some pictures.
Not sure how if your under the house your seeing where the insulation is missing in the wall behind the stove.
Was it black from mold or from being charred?
Old 03-03-2016, 03:46 PM   #3
Rewards Points: 49
I will take some pictures next time I head over there.
This is a 12 foot "crawl" space and most of the area behind the stove is exposed.
The remaining installation appears to be charred.
Old 03-09-2016, 12:52 PM   #4
Rewards Points: 49
I have attached two pictures of this area - these are taken from the crawlspace area looking towards the back of the fireplace. You can see the metal box, the area where the insulation was removed, and the charred insulation.
Insulation Behind Fireplace-img_1150.jpg   Insulation Behind Fireplace-img_1151.jpg
Old 03-09-2016, 01:06 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
What is the venting like?
That looks like standard HVAC sheet metal.
Old 03-09-2016, 03:45 PM   #6
Rewards Points: 49
I can't see the venting - will that change the insulation that's needed?
It appears to be standard sheet metal used for HVAC applications.
Do I need to use a special type of insulation with this proximity to the metal box?
Old 03-09-2016, 04:22 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 16
Find the install manual or use Google to get it. Within the manual locate the clearance from combustionable surfaces table. Keep your insulation out of that zone and you should be fine.
Old 03-09-2016, 04:52 PM   #8
Rewards Points: 49
I won't be able to access the manual for this. The fireplace box is original (the house was built in 1979) but the pellet stove was installed several years later. The manual for the stove does not reference any clearance requirements because it was installed inside the original box.
Old 03-11-2016, 07:13 AM   #9
Rewards Points: 928
Still need to know how the flue venting is handled. If this is just a box that a double wall flue goes up through, you can seal and insulate right to that sheet metal, but without knowing, you can't get a real and factual recommendation.
Insulation on 1956 Home before Vinyl Siding m1a1m10 Roofing/Siding 12 01-10-2014 11:55 PM
How to secure fireproof insulation to shute? just installed gas fireplace wantboost HVAC 14 06-14-2013 09:24 AM
Fixing 20 yr Old Attic Insulation Job BikerAggie Insulation 2 05-24-2013 11:42 AM
blow in insulation question Cool user name Remodeling 4 12-30-2010 11:24 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
