Insulation Behind Brick Fireplace Surround - Insulation - DIY Chatroom Home Improvement Forum
Old 06-11-2016, 05:56 PM   #1
Rewards Points: 322
Insulation behind brick fireplace surround
My basement has a brick and mortar fireplace surround. It was built about 2 inches away from the foundation. It measures 6 feet across. I'm finishing the basement and would like to insulate this area before framing around it. What's the way way to insulate this? So far the options I've come up with is to either stuff fibreglass behind there with a stick or try using spray foam cans and getting in there as much as possible. I've included pictures to help. Any tips would be great!
Insulation behind brick fireplace surround-image_1465685692460.jpg   Insulation behind brick fireplace surround-image_1465685707313.jpg
Lemkie is offline   Reply With Quote
Old 06-11-2016, 07:00 PM   #2
Rewards Points: 1,916
Re: Insulation behind brick fireplace surround
This is what I'd be using.
http://www.roxul.com/products/reside.../roxul+safe+45
Fiberglass in direct contact with that outside wall is going to mold up.
Old 06-11-2016, 07:09 PM   #3
Rewards Points: 322
I should be able to slide this in behind there easily. I suppose I can use some type of adhesive on the back and push it up against the foundation to make it stay there? Either that or double it up to the thickness of the gap as best as possible?
In wall fireplace install options & insulation Boydrone Building & Construction 5 01-05-2016 07:59 PM
Drill holes in brick in fireplace jeffster306 Concrete, Stone & Masonry 4 12-16-2014 06:59 AM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Painting fireplace mantel and surround asbury park Painting 8 02-21-2012 04:21 PM
brick fireplace conversion frankpoto General DIY Discussions 2 01-30-2012 08:31 AM
