Is Insulation In Attic Vermiculite? - Insulation - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By Bud9051
  • 1 Post By Nealtw
  • 2 Post By Oso954
  • 1 Post By lenaitch
Old 11-06-2017, 09:46 AM   #1
Rewards Points: 98
Is Insulation in Attic Vermiculite?
Hi, Im looking at purchasing a 1928 home outside of Boston and was concerned about this brownish pill size material used as attic insulation. Is this vermiculite? Also any idea on cost to remediate am 800 sf attic?.
Is Insulation in Attic Vermiculite?-20171105_130803.jpg   Is Insulation in Attic Vermiculite?-insulation-zoom.jpg
James8153 is offline   Reply With Quote
Old 11-06-2017, 09:54 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 856
Re: Is Insulation in Attic Vermiculite?
Certainly looks suspect. Only way to know for sure is to have it tested.
Remediation is really area dependent bases on state and local ordinances as well as the cost of labor.
The Following User Says Thank You to Windows on Wash For This Useful Post:
James8153 (11-06-2017)
Old 11-06-2017, 11:11 AM   #3
Rewards Points: 136
I agree with Windows, looks like vermiculite to me. But all vermiculite does not contain asbestos, just 90%. Based upon age and look you need to send in a sample. If the news is good then you can leave it or remove it as you wish. Personally I would want it removed so I could air seal below and install better insulation.
One factor in your favor, the contaminated asbestos originated in Libby Montana and you are in MA so yours may have come from another source.
You need to locate a testing facility and determine your local regulations and I'm sure Boston has some.
Best,
Bud
James8153 likes this.
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
Old 11-06-2017, 11:34 AM   #4
retired framer
Rewards Points: 430
Some had asbestos in it too.
There outfits that do remove it.
Do you know anyone with dust collector in the shop.
The Following User Says Thank You to Nealtw For This Useful Post:
Old 11-06-2017, 02:26 PM   #5
Oso954's Avatar
Rewards Points: 50
The vermiculite from Libby is known as Zonolite. If yours happens to be Zonolite, there is a trust fund that may pay up to 55% of the removal/containment costs.
http://www.zonoliteatticinsulation.c...al-information
Bud9051 and Nealtw like this.
Oso954 is offline   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
James8153 (11-06-2017), Nik333 (11-06-2017)
Old 11-06-2017, 07:45 PM   #6
Rewards Points: 98
thanks everyone for the replies. I will assume it is vermiculite and has asbestos in it as I developed my cost estimate for repairs. Around boston thee are a few contractors who specialize in it and from angieslist reviews I am estimating 8k on the high end. That vacuum cleaner would be a nice option to look into.
Old 11-06-2017, 07:55 PM   #7
retired framer
Rewards Points: 430
There is rental equipment.
https://www.sunbeltrentals.com/equip...emoval-vacuum/
James8153 (11-08-2017)
Old 11-06-2017, 08:13 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 68
If it tests positive for asbestos, does anybody think it's a good idea to DIY the removal?
Windows on Wash likes this.
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
Nik333 (11-06-2017)
Old 11-06-2017, 08:14 PM   #9
Rewards Points: 342
Thank you James for this question. I never knew about this & I've lived in a lot of old homes.
Nik333 is online now   Reply With Quote
Gambrel Attic Insulation ken57kogs Insulation 3 10-12-2014 03:57 PM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Attic Insulation tim1218 Insulation 4 09-07-2011 10:18 AM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
