Insulation For Attached Garage - Irregular Spaces Between Wall Studs - Insulation - DIY Chatroom Home Improvement Forum
Old 10-10-2017, 04:21 PM   #1
Rewards Points: 96
Insulation for attached garage - irregular spaces between wall studs
Hi,
As I am finishing my garage (20'x20') I am looking for an easy to install insulation. Here're my challenge:
- the spaces between wooden studs are irregular. They vary from 4" to 24" and can be anything in between.
- I have tons of electrical cables and outlets coming throughout garage walls (to be concealed). I guess this won't simplify installation either.
some more info -
- I don't need a crazy high R-value. I think ~10R should be fine.
- Currently, the walls are unfinished. From outside to inside I have: bricks, thin MDF with attached thin "carpet-like mat" (no idea what's the purpose of that), wooden studs
So question - what insulation material I should be looking at? Would the foam (spayed foam) be the best option? Rigid foam?
Denim / wool, considering irregularities, can be difficult / ineffective to install.
Can you please advise?
Jack_Zzz is offline   Reply With Quote
Old 10-10-2017, 08:57 PM   #2
Rewards Points: 2,048
Re: Insulation for attached garage - irregular spaces between wall studs
You want the easiest? Pay someone to come in and Spray foam. They spray it, let it expand a bit, screed it off, done and done in a day. Not cheap but amazingly effective.
ront02769 is offline   Reply With Quote
Torn insulation in attic/knee wall Marky82 Insulation 15 09-06-2016 09:23 PM
Finishing the garage with insulation and drywall. Snapper12 Insulation 2 10-24-2012 06:14 AM
Insulation in Garage Attic ? SaDan Building & Construction 2 05-09-2010 05:44 AM
insulation between wall studs raineydr Building & Construction 7 03-29-2010 10:01 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
