Insulation Around Fiberglass Shower? - Insulation - DIY Chatroom Home Improvement Forum
Old 12-22-2015, 08:13 AM   #1
Rewards Points: 152
Insulation around fiberglass shower?
What's the preferred method of insulating around a fiberglass shower in a basement? I've got less than 2' above the top lip of my of my shower stall, see below:
The wall to the right is lined with Foamular 250. I was thinking of doing R13 faced batts around the entire shower framing (not just the exposed 2'), but wanted to check here and ask if that was a good idea. I plan on finishing off the space with 1/2 green board, no additional vapor barrier.
Thoughts?
Thanks!
pburgh19 is offline   Reply With Quote
Old 12-22-2015, 12:18 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 986
Is the drop in on an exterior wall?
Which side?
Old 12-22-2015, 12:22 PM   #3
Rewards Points: 152
Which side?
In the photo, the right side is on an exterior wall. That wall has 2" Foamular 250 + 1" of air space + framed wall.
For the sake of completeness... directly behind the shower is about 4' of open air before reaching another foamed wall (this is where the effluent pump is located). The left side is 5' feet of open air before reaching another foamed wall.
Old 12-22-2015, 12:35 PM   #4
Rewards Points: 986
I would leave it air space. Just make sure the wall is tight. The air space will allow the energy to warm the wall and keep it from getting close to dew point.
R-10 of foam is great at that point.
Old 12-22-2015, 12:37 PM   #5
Rewards Points: 152
Ok, so just skip fiberglass and put green board up? That sure makes it easy.
Old 12-22-2015, 12:39 PM   #6
Rewards Points: 986
That's what I would do. No issues with cold surface foam boards then.
The Following User Says Thank You to Windows on Wash For This Useful Post:
pburgh19 (12-22-2015)
Tags
framing , insulation , shower
Crack in bottom of fiberglass shower bobgodd Tiling, ceramics, marble 44 05-30-2015 06:40 AM
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
Fiberglass Shower - can they be refinished somehow? cody21 Remodeling 0 04-05-2010 11:04 AM
