Insulation Around Chimney? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-22-2014, 10:08 PM   #1
Rewards Points: 80
Insulation around chimney?
Hello all. I am going to be insulating the bottom of the trusses in my garage soon and would like to know if I should insulate around the chimney.
Insulation around chimney?-dscn2526.jpg   Insulation around chimney?-dscn2527.jpg   Insulation around chimney?-dscn2528.jpg   Insulation around chimney?-dscn2529.jpg   Insulation around chimney?-dscn2530.jpg
bikerider138 is offline   Reply With Quote
Old 04-22-2014, 10:15 PM   #2
Rewards Points: 1,858
Guess the building inspector as not needed on this job.
There was suppose to be at least a 2" from the chimney to any combustible material.
Just shoot some fire rated expanding foam in the gaps. Large gaps you can use unfaced fiberglass.
Old 04-22-2014, 10:21 PM   #3
Rewards Points: 80
Thank you, Joe
Old 04-23-2014, 06:20 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 826
Use some Roxul on the chimney and seal the gaps as Joe said. Hopefully you got the chimney flashing and roof leak fixed?
Old 04-23-2014, 08:42 AM   #5
Rewards Points: 80
Yes, thankfully the previous owner took care of the leak.
Colonial Split level drew7ster Insulation 11 01-09-2013 03:44 PM
Chimney Rattles/Sways in Windy Weather cprice12 Concrete, Stone & Masonry 10 09-28-2012 10:36 PM
Chimney Liner Insulation Rockford Insulation 2 08-13-2012 09:22 AM
Chimney liner insulation Rockford HVAC 0 08-07-2012 08:38 AM
Insulation Around Chimney myfirstrodeo Insulation 2 07-19-2012 12:44 PM
