Insulation Around Bathroom Heater - Insulation - DIY Chatroom Home Improvement Forum
Old 11-15-2014, 03:55 PM   #1
bryanp22's Avatar
Rewards Points: 364
Insulation around bathroom heater
My attic right now has two layers of thin rolled insulation. I want to blow some cellulose on top of that but I am unsure what to do around the bathroom heater. Right now it's just exposed to the attic. Should I just build walls around it and leave the top exposed or can I build a box out of xps or drywall and then put some insulation on top of it?
bryanp22 is offline   Reply With Quote
Old 11-15-2014, 04:41 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 856
Build a box out of fireproof drywall.
XPS is not suitable here.
Box should ideally be sealed up and airtight unless it is drawing its air from the attic which is unlikely.
Old 11-15-2014, 05:25 PM   #3
bryanp22's Avatar
Rewards Points: 364
Fireproof drywall? Is that just half inch? I didn't know they made fireproof drywall. I always thought it was a fire barrier rated for like 30 minutes
Old 11-15-2014, 05:29 PM   #4
Rewards Points: 1,862
Fire rock is 5/8 not 1/2.
Build the box out of plywood and just line it with sheetrock.
Using a space heater in bathroom? salemguy2012 Safety 5 02-21-2014 10:58 PM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Bathroom heater insulation ajax241 Insulation 1 09-21-2012 03:57 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
