Insulation Of Alaska Pole Barn - Insulation - DIY Chatroom Home Improvement Forum
Old 09-27-2014, 10:35 AM   #1
Rewards Points: 16
Insulation of Alaska Pole Barn
I need help and fast as it is already turning to winter here.
Background:
50x60 pole barn... poles are telephone poles
14 foot ceilings... trusses with 8 on 12 pitch
New 26 ga metal on the outside. Metal is attached to 2x6 lath that are attached to poles.
Old owner built 2x4 walls on the inside of the poles on the inside of the barn
This creates approx 16 inch gap between 2x4 wall and metal
Barn is located in Interior Alaska... temps regularly -20
I am going to insulate would love to spray foam but can not afford wish i could...to cold already even if I could afford.
I have entertained the both Batt and blown insulation for the walls. 16 in gap allows for whatever I want to put in R-38 even... BUT I can fill the walls with blown insulation for the SAME MONEY and just seems like why not.
Question... If I use batt insulation will the gap be a bad thing or is it needed... only concern about blown ... remember 16 inch of it is it will rest against the metal directly... is this bad. I have called about the cellulose against metal and the manufacturer says ok. I am looking more at a moisture issue if there will be one. Obviouls vapor barrier over the outside.
Funds are limited so please keep that in mind with the comments
26 this morning in Alaska I will post pictures as soon as I figure out how
Alaska1 is offline   Reply With Quote
Old 09-27-2014, 10:58 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Post any pictures you can. Can you navigate behind the 2 x 4 framed wall and the metal?
Old 09-27-2014, 11:50 AM   #3
Rewards Points: 16
I can get back there but it is very difficult especially up high. But please any ideas would be appreciated.
Having difficulty figuring out how to post pictures... the paperclip is not present in my tool bar
Bottom line do you think filling up the space with blown insulation is ok.... just seems ridiculous to spend the same money on batt for less R value
Old 09-27-2014, 03:20 PM   #4
Rewards Points: 144
Click go advanced and then manage attachments to post pics
mako1 is offline   Reply With Quote
Old 09-27-2014, 06:33 PM   #5
Rewards Points: 16
tried to post again but no luck I see that at the bottom of the thread I am not allowed to post for some reason. Have a message into a moderator.
Hopefully someone can help with the word picture i painted. Really need to get this done as it is cold right now
Old 09-27-2014, 06:38 PM   #6
Rewards Points: 906
You need a couple more posts (5 minimum I think) in order to post up pictures.
Old 09-27-2014, 07:49 PM   #7
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,778
The only thing I see when you mention blowing in 16" into a wall cavity is the insulation settling and then leaving a void at the top.
Moisture should not be present between the insulation and metal as no warm air from inside can meet the metal.
123pugsy is offline   Reply With Quote
Old 09-27-2014, 11:46 PM   #8
Rewards Points: 16
thanks.. i thought about the settling and will be leaving the top foot or so available to add if needed. I have found insulation blown blanket for sale here. 6000 ft2 for only 140 bucks. that is what I was going to use... then cover with vapor barrier.
Old 09-28-2014, 02:15 AM   #9
Rewards Points: 16
posting one last time to see if the 5x minimum post is required so I can get some pics up.
Old 09-28-2014, 02:19 AM   #10
Rewards Points: 16
Appears that did not work. I have been reading a great deal about insulation all over the internet and just can not find much concerning my application. With a metal building most of the time it has a form of insulation between the metal and steel or lath. In my case it does not which might actually be good. I am just wondering if I seal up the vapor barrier really good pouring the 16 inch cavity full of insulation with it touching the metal should be ok. Only thing is no matter how you seal up the vapor barrier it always gets holes punched in it. Screws nails, for stuff on the walls ext.
Perplexed to say the least just want to get this thing done.
Old 09-28-2014, 08:36 AM   #11
Rewards Points: 906
Blown in insulation isn't an option in that wall space unless you net the back of the wall and blow in via dense pack to stop air movement.
Spray foam is your best option here but it will not be cheap.
Next best option, although it would take you forever, would be to put foam on the backside of the 2x4 walls, use batt insulation, drywall the interior.
The tricky point will be the transition in the wall to roof detail.
Pictures are a must.
Feel free to email them to me if you want: [email protected]
Old 09-28-2014, 11:54 AM   #12
Rewards Points: 16
WoW: Why will that much insulation not work. It will be like R50+ way to much but still. I am not sure what you mean by dense pack. I will email you some pics since the thread is still not allowing me to post pictures
Old 09-28-2014, 05:30 PM   #13
Rewards Points: 906
Pics attached.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Alaska1 (09-28-2014)
Old 09-28-2014, 09:19 PM   #14
Rewards Points: 16
I spent a great deal of time in the barn today... After reviewing another way I could do this is to attach foam board (R_TECH) to the laths on the inside. This would keep the insulation off the metal and would allow for some air flow behind the board throughout small openings that make up the ridges of the metal... small opening but a lot of them...
Thoughts on this method....???????? as oppose to the blanket over the front and fill the cavity without the board... cheaper that way for sure..
Also I some R13 batt.. paper faced for another wall that separates the barn ... 2x6 studs and was thinking about just putting a double run in that wall and using up some material I have. this would give me R-26 but would put the paper face in the middle .. Any problems with that method as well.
I think I should tell everyone that I live in rural Alaska... nearest Lowes is 2x hours... nearest fuel is 30 min... so you see my dilemia as I do projects you use what you have or you wait and wait for the next trip to town...
any advice or opinions welcome
Old 10-01-2014, 08:41 PM   #15
Bob Sanders's Avatar
Rewards Points: 2,536
That's what I was going to suggest. I like it better than spry foam. I don't like using spray foam in walls. It's too hard doing work later on in years should you decide to change things a little.
Bob Sanders is offline   Reply With Quote
Insulation in a Metal Pole Barn Mark76 Insulation 15 12-30-2012 06:58 PM
Pole barn vs steel I beam building. Do they compare structurally? viper Building & Construction 0 05-23-2011 06:17 PM
pole barn into apartment/house tcham34 Remodeling 11 09-15-2010 10:38 PM
pole barn ? @ span length & size lumber req.. ugabulldog Building & Construction 3 09-11-2008 01:07 PM
Pole Barn johns Building & Construction 3 01-27-2008 01:56 PM
