Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 08-04-2016, 07:27 AM   #1
Rewards Points: 4
insulation
I have a metal roof that is on top of plywood, do i have to worry about sweating?
I bought a house with a room addition already added but the previous owner did not put house wrap on, how can I fix this without rebuilding the structure? The inside walls are not finished(no insulation or drywall yet)
I cannot afford spray foam insulation.
RonR399 is offline   Reply With Quote
Old 08-04-2016, 08:34 AM   #2
Rewards Points: 1,858
Re: insulation
Got some pictures?
Is there siding already on? If so what type?
Not having house wrap or at least tar paper under any siding is a huge mistake.
It helps to seal air leaks and acts as a drain plain behind the siding.
Without it your far more likely to have sheathing damage and mold.
Old 08-04-2016, 01:09 PM   #3
Rewards Points: 4
There is no siding on yet and it will be next year before it is installed. I need to move in soon.
Old 08-04-2016, 05:39 PM   #4
Rewards Points: 4
Re: insulation
could I put on the house wrap for this winter and do the siding next year? I could staple the wrap more than normal so it would hold.
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
