Insulating Wooden Shed/Outbuilding - Insulation - DIY Chatroom Home Improvement Forum
Old 03-17-2018, 11:10 PM   #1
Hello everyone! Im going to be insulating my 10x16 high barn wooden shed. The shed has the lofts on both sides for storage. I have a couple of questions. The shed come with an eve vent on both sides of the shed near the peak. Will I need to cover those up or leave them open for ventilation? Also, the ceiling does have a radiant barrier installed under the wood and shingles as you can plainly see and read that's what it is. Should I insulate between the 2x4 studs of the ceiling as well? I plan on installing a window AC unit for the summer and possibly space heaters for the winter. Thanks in advance for any help/advice!
Hilbilydrummer is offline   Reply With Quote
Insulating a new wooden shed CharleneB Insulation 5 10-15-2017 10:10 PM
Insulating wooden exterior door not in use for winter dwolf Insulation 6 02-21-2015 05:09 PM
Wooden Windows or Plastic? Richuw Windows and Doors 15 04-05-2012 10:16 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
