Insulating/venting Shed - Insulation - DIY Chatroom Home Improvement Forum
Like Tree11Likes
Old 08-09-2017, 12:03 PM   #1
Rewards Points: 12
Insulating/venting shed
Hi. New to forum and diy, so please be kind.
I am converting a shed into a studio for music and am currently stuck. It has a corrugated metal roof laid over wood planks. I haven't yet looked too see what, if anything, is between metal roofing and wood planks. Someone has already put insulation batt in rafters. I want to drywall the ceiling for a more finished look.
Should I:
1) leave insulation, put up sheetrock for ceiling and call it good.
2) take out insulation and put new insulation in ceiling joists instead, then do sheetrock.
3) leave insulation in rafters AND add insulation in joists and then sheetrock.
4) do any of the preceding ideas and add some sort of vent(s)
I live in Seattle. The enclosed space ("attic"), after adding sheet rock we'll measure only approximately 100 cubic feet.
The "living space" is well ventilated with two windows.
Attached are some pictures.
Thank you for any help you offer.
Joe
Insulating/venting shed-20170809_094131_1502297939338.jpg   Insulating/venting shed-20170809_094102_1502298055099.jpg
Kunkel19 is offline   Reply With Quote
Old 08-09-2017, 03:03 PM   #2
retired framer
Rewards Points: 364
Re: Insulating/venting shed
Will you be cooling or heating the shed.
Nealtw is offline   Reply With Quote
Old 08-09-2017, 03:15 PM   #3
Rewards Points: 124
Hi Kunkel and welcome to the forum.
If you add drywall across the bottoms of those ceiling joists then you do not want the insulation in the rafters. A standard approach would be to move that insulation down to the ceiling and then create some ventilation for the attic space above. There is not a lot of room up there and I doubt you will need to meet local energy codes for this small space but as much as reasonably possible would be good. Soffit vents for low venting and ridge or gable vents for high.
Bud
Bud9051 is online now   Reply With Quote
Old 08-09-2017, 05:47 PM   #4
Rewards Points: 12
Good question. In the coldest months of winter, I will be using an oil-filled space heater.
Joe
Old 08-09-2017, 06:00 PM   #5
Rewards Points: 12
Bud
Thanks for the response and welcome, Bud.
Is the venting going to be more about moisture or energy codes? Would I need to do BOTH ridge venting and soffit venting? Attached is what the eaves look like. The soffit venting might look like something in the second picture, yes?Insulating/venting shed-20170809_155413-1-.jpg
Nealtw likes this.
The Following User Says Thank You to Kunkel19 For This Useful Post:
AIRLOCK (08-19-2017)
Old 08-09-2017, 06:06 PM   #6
retired framer
Rewards Points: 364
Joe
If you are not adding heat or cooling insulation is a waste of effort.
I would pull the insulation and make sure you have venting under the eaves on both sides. If you can't get venting at the ridge then second best would be a small vent one each gable end. Lay non papered batts across the joists and then the paper faced between the joists. In order to stop the insulation from blocking the vents at the eaves you would need chute stapled to the roof sheeting.
http://www.homedepot.com/p/ADO-Produ...4480/100533902
That will save you a few degrees in summer and really help in the winter.
When you do drywall it will want to be taped filled and painted to keep moist out of the attic,
jlhaslip likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
Old 08-09-2017, 06:11 PM   #7
Rewards Points: 12
Thanks for all the info! If the insulation isn't wet or crushed at all, do you think I could reuse it?
Joe
Old 08-09-2017, 06:19 PM   #8
retired framer
Rewards Points: 364
Joe
Let it dry if it is wet. Just throw it out in the sun for a few days.It is just glass.
Old 08-09-2017, 06:20 PM   #9
Rewards Points: 124
Venting the attic space is about moisture. During cold conditions any air that seeps through to that space will find a cold roof and form condensation/ice.
You would want some of each, high and low venting. I don't think the normal rules apply as no showers, large gatherings, cooking (minimal), and other normal moisture sources so some venting is probably close enough.
Is that heater you are considering vented to the outside. Being a combustion appliance it will also need combustion air coming in. If well insulated electric heat might be more appropriate for that size space.
Bud
Nealtw likes this.
The Following User Says Thank You to Bud9051 For This Useful Post:
Old 08-09-2017, 06:30 PM   #10
Rewards Points: 12
Bud
It's one of these jobbers in the picture below. I don't think combustion is part of it. Maybe I misnamed it?
I have a working wall mounted electric heater I was considering actually...
Old 08-09-2017, 06:44 PM   #11
Rewards Points: 124
If the one pictured is oil filled electric that would be fine, the oil adds mass to release the heat at a slower rate. But ant electric heater would be fine. Let the hot air blow through a stack of bricks and you have the mass advantage. The key is, for a small space you don't want any combustion.
Old 08-11-2017, 04:55 PM   #12
Rewards Points: 12
To help me with my understanding, could someone please explain why it would not be good to put up drywall and just leave insulation in rafters?
Thanks,
Joe
Old 08-11-2017, 07:51 PM   #13
Rewards Points: 124
Small amounts of moisture are still going to move through drywall due to its permeance. Same reason food products get freezer burn when wrapped in plastic, the moisture can move through it. With fiber insulation it traps that moisture and creates the conditions necessary for mold. Different type of ceiling but same results pictured in this link.
http://www.greenbuildingadvisor.com/...hedral-ceiling
Bud
Old 08-17-2017, 04:57 PM   #14
Rewards Points: 12
[QUOTE=Bud9051;4515881]Small amounts of moisture are still going to move through drywall due to its permeance. Same reason food products get freezer burn when wrapped in plastic, the moisture can move through it. With fiber insulation it traps that moisture and creates the conditions necessary for mold. Different type of ceiling but same results pictured in this link.
Thanks again. So I thought there was Ridge venting because of foam I saw under cap. When I took the cap off, I found this (picture). To make this an actual vent, do I need to saw a hole through this black paper to the open air in the attic below?
Insulating/venting shed-15030070397931623760429_1503007058263.jpg
Old 08-17-2017, 05:18 PM   #15
Rewards Points: 124
If there was an actual ridge vent over that and it was intended to be ventilation and not decoration then the black paper, underlayment, should probably have been cut away to permit air flow. I hedge a little as this is a shed and hard to be positive from my chair.
Bud
Nealtw likes this.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
[Canada Code] Sharing 240V and 120V appliance on same circuit in workshop shed? mdrejhon Electrical 37 11-13-2016 07:53 PM
shed repair discussion JKeefe Building & Construction 7 07-26-2014 07:22 AM
Zoning issue with planned shed Ler0y Jenkins General DIY Discussions 15 02-01-2012 12:41 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
