Insulating Space Betweek Joists That Run From Crawl To Basement - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bud9051
Old 11-12-2018, 03:50 PM   #1
Rewards Points: 76
Insulating space betweek joists that run from crawl to basement
I have an older house with a partial basement and then crawl space where an addition was put in about 20 years ago. The floor joists run from the basement over the sill plate and into the crawl and these spaces look like they were just stuffed with insulation (see pictures). Is this correct or is there another way to seal these spaces?
Insulating space betweek joists that run from crawl to basement-img_8305.jpg   Insulating space betweek joists that run from crawl to basement-img_8307.jpg
rkfast is offline   Reply With Quote
Old 11-12-2018, 04:18 PM   #2
Rewards Points: 98
Re: Insulating space betweek joists that run from crawl to basement
Add your climate region or nearest big city to your profile so it will show up with each post, it helps.
Are either the basement area or the crawlspace heated?
Do both have concrete floors?
Is the crawlspace vented?
There are tow issues, humidity and heat. Once we determine those then we can advise on closing off or not. In some cases it is better to leave those cavities open and seal (encapsulate) the crawl.
More details.
Bud
de-nagorg likes this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 11-12-2018, 04:21 PM   #3
Rewards Points: 76
More details.
Bud
Sorry....Long Island. Neither space is currently heated, but plan to heat the basement when I finish it. Basement has a concrete floor and the crawls all have rat slabs (concrete). No dirt. Plenty of venting in crawl space.
Old 11-12-2018, 04:50 PM   #4
Rewards Points: 98
Two options on a crawlspace, vent it and insulate the floor above orclose the venting and insulate the foundation. The second one is followed by adding heat to the crawl.
One advantage of heating the crawl with the foundation insulated is warmer floors. Your activity above helps to determine which is desirable.
If you are going with insulated floors and ventilated then you need some sort of solid blocking in those joist cavities, Fiberglass insulation is an air filter.
Bud
Old 11-12-2018, 05:00 PM   #5
retired framer
Rewards Points: 324
With a vent CS there should be joist material cut to fit between the joist and installed from the CS side on top of the sill and sealed from the inside. Even as best you can around heat ducts and such. And then insulated from the inside.
Insulating heating pipes in crawl space orange HVAC 10 09-24-2013 08:53 AM
Insulating my crawl space jimmyfloyd Insulation 2 11-10-2012 04:17 PM
Crawl Space Questions mark2741 Building & Construction 1 12-23-2011 11:20 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
