Insulating A Small Roof/soffit Section - Insulation - DIY Chatroom Home Improvement Forum
Old 01-31-2019, 12:17 PM   #1
Insulating a small roof/soffit section
I have an issue where cold air is coming into one of our upstairs bedrooms. You can feel the cold air in the floor. It seems to be coming in where we have a smaller roof section on the back of our house. The roof isn't part of our main attic -- it is more of a decorative section to help break up the house. We had insulators come and they drilled holes in the bedroom floor along the baseboard and blew in insulation, but it still feels quite cold. This room is also the farthest away from our furnace, and I think there isn't quite as much heat getting to it. I just wanted to see if anyone had advice on how to insulate it. Is it ok to insulate over the soffit on this section since it's not really a true attic-type space? Would it be best to try removing the soffit from the outside and trying to blow insulation in that way?
I'll comment again with an image of what I'm talking about.
bach13 is offline   Reply With Quote
Old 01-31-2019, 12:21 PM   #2
Re: Insulating a small roof/soffit section
I attached an image of our house with the section I'm talking about circled in red.
Insulating a small roof/soffit section-house-backside.png
Old 01-31-2019, 12:24 PM   #3
Rewards Points: 92
Yes, pictures inside and outside would help.
My first thought (wild guess) is the small roof section may not be air sealed away from the framing cavities of the house. An example would be building that roof before they applied the sheathing, but a guess.
What is below this bedroom?
Bud
OK, you got that in while I was posting .
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 01-31-2019, 12:31 PM   #4
Bud
Below the bedroom is our dining room and part of our kitchen. Along the ceiling/wall seam there is some condensation that develops on extremely cold days.
Old 01-31-2019, 12:40 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 818
Try to reduce the humidity on the immediate term.
With regards to that space, while they are treated as vented in many cases, they are never done properly as there is never any exhaust.
Is the roof due to be done soon? If so, that is the time to demo that area and I would just insulate it at that point. You have two options:
-Insulated and air seal the floor of that area and provide for some exhaust air along the roof-wall intersection...or...
-Spray foam the area and treat it as conditioned if you can get some air circulation in there via the HVAC access.
Old 01-31-2019, 12:54 PM   #6
Rewards Points: 92
What is covering the bottom of that overhang? is it a perforated soffit?
Bud
Old 01-31-2019, 01:09 PM   #7
Bud
I think it is perforated soffit. I think it's alternating where there are some sections perforated and some are solid. I'll have to take a look when I get home.
Old 01-31-2019, 01:15 PM   #8
APA
Rewards Points: 382
If it has soffit, you can remove the soffit and stuff some insulation in the cavity. It's not perfect air sealing, but it made a world of difference in a similar situation for me. I am going to do it right when the weather warms. You have warm inside air hitting a freezing cold wall, hence the moisture. Stuffing the insulation would help...
APA is offline   Reply With Quote
Old 01-31-2019, 01:15 PM   #9
Rewards Points: 92
Perforated is usually vinyl and can be removed to see what was done to the exterior wall. if it is cold vinyl can break easily. if there is no or missing sheathing then that's a problem. Most likely no house wrap and possibly a seam at 8' in the sheathing. All seams and gaps would need to be sealed.
Take a picture.
Bud
Old 01-31-2019, 09:33 PM   #10
Take a picture.
Bud
Ok I checked and it's not perforated. It is the solid aluminum type. Too cold to do anything with it right now, but maybe I can take a peak once it warms up.
Old 01-31-2019, 09:51 PM   #11
retired framer
Rewards Points: 308
Usually the skirt roof is just nailed on the side of the building but this may have extended floor joists missing the solid blocking over the wall between the joists. When you replace the soffit, use vinyl.
Reparing small section of rotted wooden siding trim/sil Dimeron Roofing/Siding 7 11-03-2016 11:28 AM
Seeking advice for repairing small tear in bathroom linoleum floor lonlonmilklover Flooring 3 01-10-2013 02:08 PM
Insulating a small steel shed - cost effectively = Help? fredrick Insulation 9 09-01-2012 09:15 AM
How To Refinish A Small Section Of Hardwood Floor jdbs3 Flooring 3 06-25-2012 02:06 PM
Where to find bulk small wire? Red Squirrel Electrical 13 06-14-2012 09:38 PM
