Insulating Small, Old Slanted Ceiling And Knee Walls In A Finished Attic Room. - Insulation - DIY Chatroom Home Improvement Forum
Old 07-30-2014, 02:33 PM   #1
Insulating small, old slanted ceiling and knee walls in a finished attic room.
Hi folks, also posted this in a similar forum-
My first post! My wife and I just embarked on a fullscale rehab of our 200 year old house. The man, oldest part is a trinity with one room stacked on top of the other. The 3rd floor room is finished w/ slant ceilings and knee-walls with dormer window on each side of the slant. Nothing is insulated. It's a small room, about 10' x 10' x 6.5' (peak).
We just did the windows and had to cut holes in the knee wall under each dormer to repair damage from the old, poorly installed units. I'm also having a duct run up so needed one side a bit open anyhow. I wanted to insulate to some degree though figured I'd wait it out until maybe next summer, but now that some of the walls are open....
I'm hoping to keep the slant plaster/lath walls up and do something via the opened knee walls. Alternately, I'd be OK with drilling holes to pump something in. Basically want to get the best possible, realistic R-value. I don't expect to hit the 38 called for in Philadelphia...
I know this is very general advice seeking, but any suggestions to the "easiest" way to DIY this would be great. I'm hoping to seal the entire slant and pump cellulose into it. Anybody have experience with this sort of thing?
cjs4775 is offline   Reply With Quote
Old 07-31-2014, 11:52 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,054
Capes and sloped ceilings are tricky.
Post up a few pictures and I will give you some ideas.
(Partial) Radiant Barrier Above Finished Attic? Lascaux Insulation 11 09-26-2012 07:56 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Ideas for retrofitting baffles/insulation in vaulted ceiling of built out attic room rachelsue20 Insulation 5 04-28-2012 07:49 PM
Building Knee Walls in the Attic Jimmybrp Building & Construction 12 12-23-2011 01:22 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
