Insulating Short Stretch Of Circular Duct That Has Damper - Insulation - DIY Chatroom Home Improvement Forum
Old 07-12-2014, 01:50 PM   #1
Rewards Points: 1,062
Question
Insulating short stretch of circular duct that has damper
I have a condensation and drip page problem where my 8" exposed circular AC duct comes out of the ceiling. Above the ceiling is the attic, meaning it gets pretty hot. As you can see in the pictures, the small (maybe 6-9") stretch of the pipe between the plenum box above and where it comes out of drywall (will come out of drywall) is uninsulated, the guy left it like that because a damper is there that I want to have access to through a future small panel door. So he couldn't just wrap around because the damper was in the way. I didn't think leaving it like that could cause condensation but it does.
My question is, is there some kind of (preferably self-adhesive) insulation tape that I can apply around all but the leeway of the damper to prevent or reduce condensation? Or would you recommend something else?
Insulating short stretch of circular duct that has damper-imag0144.jpg   Insulating short stretch of circular duct that has damper-imag0145.jpg
Old 07-12-2014, 09:21 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,748
I would build a box out of foam that is above the damper on the attic side and seal it to the attic floor.
Seal all the connections in the line with mastic as well.
Tags
condensation , duct , hvac , insulation , pipe
insulating duct work in basement Master Brian HVAC 10 05-19-2009 11:28 AM
Insulating a return duct ? iMisspell HVAC 2 12-03-2008 01:47 AM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
closing circular duct steve6 HVAC 7 02-22-2007 09:06 PM
Insulating duct run in vented crawlspace Magus HVAC 2 11-29-2006 04:09 PM
