Insulating Rim Joists I Can't See - Insulation - DIY Chatroom Home Improvement Forum
Old 02-07-2015, 07:42 PM   #1
Rewards Points: 396
Insulating rim joists I can't see
so I have a soffit that is housing a lot of ducting right up against an exterior wall, so I can't just take down drywall and spray foam it like I want to.
Is there any spray foam that I can put through a decent length of hose? It's about 4 feet of soffit and I can get up on the other side of the soffit, so I was hoping to snake a house over the soffit (since it's running perpendicular) and just spray to fill the area like I sometimes do with the small sprayfoam cans.
Any ideas?
MLMIB is offline   Reply With Quote
Old 02-07-2015, 10:27 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 766
Pictures?
Old 02-08-2015, 09:43 AM   #3
Rewards Points: 396
That is looking right at the soffit. There is a 1" piece of wood near the top of the wall, but past, from what I can tell, is the ducting.
here is looking down the soffit
Old 02-08-2015, 11:47 AM   #4
Rewards Points: 766
Sounds like it might be a recipe for disaster to be perfectly honest.
There are closed cavity foams that are used to retrofit insulate interstitial wall cavities that were either under insulated or uninsulated, however, I don't know of any DIY applications for said insulation methodology.
How tight is that ductwork to the ribbon board? I.e. how much clearance from that outside wall do you have?
If there's a decent amount of clearance, it would probably make better sense to rip out the strip of drywall from the bulkhead, insulate it via standard applications, and and just re-drywall that section.
Old 02-08-2015, 02:50 PM   #5
Rewards Points: 396
if I took down the ribbon I'd have about 2 inches, maybe, of space to work in. if I took down the drywall I'd just be staring at duct. The ducts might be 2 inches up, but certainly not enough for a standard install of putting foam boards up and sealing it with spray foam from a can.
I had some open cell foam installed in my walls a few years back and they did it by sticking a 2 inch hose in the wall through maybe a 4 inch hole and filled the entire cavity that way, I was hoping I could do something similar but with closed cell foam.
Any thoughts? or should I just look for a pro to come over and do it since they probably have better systems with more pressure to work with a longer hose.
Old 02-08-2015, 10:11 PM   #6
Rewards Points: 766
Might be easier to have a pro look at it.
Make sure the perm ratings are right at the bands as well.
Old 02-11-2015, 09:35 PM   #7
Registered User
Rewards Points: 526
IMO, remove the ledger board, check to see if you actually need it after the work- supporting ?. Add some 1/2" thick polyiso board to the rim joist, foil-faced with caulking on the top edge/sides before installing- for air tight seal. Then just compress some fiberglass insulation pulled from batt, to fill the joist cavity (interstitial). Problem with foam, it may cause a crease in the ducting that could restrict air flow/turbulence or move/miss-align the run/joints. I've used the clear tubing 2' long with the canned foam before but even the door/window (low-expanding) may expand too much in those tight areas- and very difficult to keep air-pocket free- especially with no vision above the pipe. Compressing R-13 (3-1/2") to 1" will give you at least R-4.4 per inch thick...
Gary
Old 02-12-2015, 07:18 AM   #8
Rewards Points: 766
That's a good idea from Gary.
Post up a picture viewing the home from the outside.
If you have vinyl siding it's much more doable as compared to some other, less serviceable claddings.
Insulating Garage Ceiling w/ Access to Joists KpR Insulation 22 12-31-2014 11:01 AM
Best way to frame in a lateral bracing between joists miamicuse Building & Construction 2 03-19-2012 10:08 PM
Insulating between joists with double brick wall. rugby style Building & Construction 3 12-20-2010 02:25 PM
Spray foam insulating joists in basement? peethree Building & Construction 13 11-28-2010 08:54 AM
Insulating Joists over concrete sandyman720 Building & Construction 5 05-24-2007 12:52 PM
