Insulating Rim Joist With XPS But Heat Protection Needed - Insulation - DIY Chatroom Home Improvement Forum
Old 10-17-2015, 11:02 PM   #1
Rewards Points: 26
Insulating rim joist with XPS but heat protection needed
I'm planning on using Extruded polystyrene on the furnace room of my basement, see pic below. As you can see they have used fiberglass and and is just stuffed every which way around the pipes and things.
However I'm now reading that I need to protect the insulation from potential fires. I don't plan to use drywall since its a unfinished part of the basement and I don't plan on finishing it. Also from the pic above you can see a plastic barrier. Its only stapled and says its something about flame resistance, see below pic.
Also I'm reading that vapor barrier in the basement is a no-no? Just want to confirm this.
I'm located in Quebec Canada in case that changes any of the regulations.
Tjvelcro is offline   Reply With Quote
Old 10-18-2015, 07:40 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 818
Foam/caulk/seal the XPS in place and cover with roxul.
The Following User Says Thank You to Windows on Wash For This Useful Post:
joecaption (10-18-2015)
Old 10-18-2015, 08:27 PM   #3
Registered User
Rewards Points: 526
Your code requires it on the wood rim area as per new Govt. guide of this year; http://www.nrcan.gc.ca/energy/effici...ion/15639#a6-2
Read 6.2.6 and note the "protective" covering on the foamboard... ask local AHJ if foil-faced foamboard will meet the fire rating as this shows it does; http://building.dow.com/en-us/produc...1-b48282f3c7b7
Gary
Geothermal Heat pump install help needed! nc73 HVAC 1 12-31-2013 12:37 AM
Insulating Recessed Rim Joist matt151617 Insulation 4 09-03-2012 08:28 PM
Insulating rim joist bseries4life Insulation 5 04-01-2012 10:11 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
Insulating for radiant heat mugen HVAC 10 02-22-2010 10:06 PM
