Insulating Metal Roof For Pole Barn - Insulation - DIY Chatroom Home Improvement Forum
Old 09-06-2020, 01:49 PM   #1
Rewards Points: 90
Insulating Metal Roof for Pole Barn
I know that the most popular way to insulate metal roof for pole barn is to spray it with foam. But I am wondering what did the ole timers down before there was spray foam to control condensation on the underside of a metal roof. I know the other choice is double bubble but the net is full of reason not to use it since life span is about 10yrs. I know location is everything but this will be in East Tx where its hot and humid just like lot of other places.
karoc524 is offline   Reply With Quote
Old 09-06-2020, 02:04 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 460
Re: Insulating Metal Roof for Pole Barn
Spray foam is about the only way to do it properly since there was no diaper insulation installed during construction. Spray foam will eliminate the need for air space above the insulation and ridge/soffit venting. Without the air over the insulation the metal roof will sweat and cause water problems down the road.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
