Insulating A Hot Air Garage Duct - Insulation - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By Bud9051
  • 1 Post By Old Thomas
Old 03-07-2020, 08:32 PM   #1
Rewards Points: 810
Insulating a hot air garage duct
I have a rectangular hot air duct in my garage that is sheetrocked. A neighbor pulled down his sheetrock and it was filled with black mildew probably from the air conditioning. He left it plain metal as several other neighbors have a bare metal duct in their garage. It makes for a nice warm garage in the winter but I want to pull down my sheetrock and put 2" foam around the rectangular duct.
How should I fasten the foam board? Construction adhesive? Contact cement? Should I hold it with metal duct tape dealing the edges with the same? Should the ends be sealed with caulking? Type? Then paint the foam white?
Or should I build a wooden frame and use 1/4", 3/8", sheetrock?
JLawrence08648 is offline   Reply With Quote
Old 03-07-2020, 08:43 PM   #2
Missouri Bound's Avatar
Rewards Points: 4,188
Re: Insulating a hot air garage duct
There is foil backed insulation designed for ductwork. Before you install any of that you need to seal the duct completely.
https://www.hvac-for-beginners.com/duct-insulation.html
Look around on this website for some ideas.
Do you want it your way or the right way?
Old 03-07-2020, 08:50 PM   #3
Rewards Points: 154
Not a pro with hvac, but the sheetrock might be required as a fire barrier between house and garage. Fumes from vehicles are carefully isolated from living space.
Bud
Missouri Bound and Dave Sal like this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 03-07-2020, 10:43 PM   #4
Rewards Points: 5,160
Does it supply the garage or simply pass through the garage?
If it supplies, FYI: Section M1601.6 of the International Residential Code says, “Furnaces and air handling systems that supply air to living spaces shall not supply air to or return air from a garage”.
It was in the NY code far previous to the writing of the IRC. Not sure about your state, but they are usually similar.
If it just passes through, ok. However, most codes prohibit exposed foam and require at least covering it with gwb.
Bud9051 likes this.
Old Thomas is offline   Reply With Quote
The Following User Says Thank You to Old Thomas For This Useful Post:
JLawrence08648 (03-08-2020)
Old 03-08-2020, 05:44 AM   #5
retired framer
Rewards Points: 576
You will be able to copy the frame work you have now or post pictures of what you have.
The drywall on the ceiling of the garage is 5/8" fire rated.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
