Insulating Exterior Garage Walls With 2x 6 Studs - Insulation - DIY Chatroom Home Improvement Forum
Old 07-28-2014, 04:09 PM   #1
Rewards Points: 71
Insulating exterior garage walls with 2x 6 studs
Im insulating my exterior garage walls and the fiberglas r-20 insulation I purchased is in 23 inch wide pieces and my studs are 16 inches apart oc.
I've never done this before is it normal that I need to cut down each piece to a 16 inch width?
Sent from my iPhone using diychatroom.com
RichTibo is offline   Reply With Quote
Old 07-28-2014, 04:14 PM   #2
Rewards Points: 1,902
Bought the wrong insulation.
Should have been for 16" spacing and R-19.
Old 07-28-2014, 04:17 PM   #3
Rewards Points: 71
Ok i thought r20 was for exterior garage walls and it is for 2x 6 studs. Is this available in r19?
Old 07-28-2014, 04:24 PM   #4
Rewards Points: 376
Return it for 16 OC studs and staple the flanges/flaps to the edge of the studs.
SeniorSitizen is offline   Reply With Quote
Old 07-28-2014, 04:28 PM   #5
Rewards Points: 71
Will do but r19 or r20?
Old 07-28-2014, 04:51 PM   #6
Rewards Points: 376
Whatever the manufacturer made for 2x6 studs. If there is a chance r20 will be compressed I would choose r19.
Old 07-28-2014, 04:53 PM   #7
Rewards Points: 71
Great!
Thank you
Old 07-30-2014, 01:06 PM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Don't bother with the cutting. Get the right stuff and specify HD (high density) batts.
Insulating interior walls Maine1 Insulation 2 12-05-2012 11:39 PM
Insulating interior basement walls brazzle Insulation 3 05-04-2011 07:24 PM
Insulating interior walls - soundproofing Branden Building & Construction 2 11-16-2010 12:05 PM
insulating cement basement walls against moisture farmgirl81 Building & Construction 10 11-01-2010 10:23 PM
insulating between steel studs drewhart Building & Construction 1 09-05-2008 08:07 AM
