Insulating An Exposed Beam Ceiling. - Insulation - DIY Chatroom Home Improvement Forum
Old 05-15-2020, 02:27 PM   #1
Insulating an exposed beam ceiling.
I'm trying to get things started to insulate my home that was built in 1946, and has no insulation. I'm starting with an add on room 21' x 14' with a flat roof no attic, just exposed beams. I was thinking of adding some 2x4 and putting those foam boards with foil then drywall on top. Will that work? And then for the rest of the house I was going to put the blow in cellous in the attic.
St3v3mrtnez is offline   Reply With Quote
Old 05-15-2020, 02:36 PM   #2
retired framer
Rewards Points: 604
Re: Insulating an exposed beam ceiling.
You need to look at ventilation above and the amount insulation needed and a ceiling that will not leak air.
On the flat roof, how tall are the (beams) ceiling joists.
Does the roof extend past the outside wall and by how much.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 05-15-2020, 02:52 PM   #3
Yes they come out of the wall at the end about a foot and a half, the joist are 6x10 I think. From the floor up where the room connects about 8.6ft to the end of the room 8ft.
Old 05-15-2020, 04:05 PM   #4
retired framer
Rewards Points: 604
Are you sure they didn't put insulation above the roof as in foam board under the roofing?
figure 7-14
Old 05-16-2020, 08:46 AM   #5
Rewards Points: 56
I guess it will work, Steve. Just be extra careful while doing the job.
rmoore853 is offline   Reply With Quote
