Insulating And Covering HVAC Duct In Garage - Insulation - DIY Chatroom Home Improvement Forum
Old 11-07-2016, 07:50 AM   #1
Rewards Points: 20
Insulating and Covering HVAC duct in garage
Hi, we have some HVAC ducts that run along the ceiling of our garage. I assume they are feeding the rooms above them. Currently they have some really old insulation and some kind of white HVAC tape covering them. Its coming loose, it wasn't very well done (was like this when we moved in), and just looks bad. It sags down a bit and the ceiling isn't super high to begin with. What would be the best way to insulate these ducts and then cover them up so they are more aesthetically pleasing? I need it to look a lot nicer. For reference, it runs most of the width of the back of our 2 car garage.
payne.kj is offline   Reply With Quote
Old 11-07-2016, 08:13 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 928
Re: Insulating and Covering HVAC duct in garage
Pull off the insulation, seal all the connections with mastic.
Prettiest way would be to build a small bulkhead around them and insulate with some spray foam or rigid foam.
Old 11-07-2016, 08:20 AM   #3
Rewards Points: 20
Thanks! I should have prefaced this by saying I'm a newbie with home repair/improvement projects so I am looking for more simple solutions that might still look nice. I wish I had the ability to do what you said and i can't afford to pay someone to do that. Just wondering if there's a better way to do what's already there.
Tags
duct , garage , hvac , insulation
Insulating a decorative "wishing well" covering a well JohnnyK624 Insulation 6 11-17-2014 02:51 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
