Insulating Cathedral Ceiling W/ 2"x 6" Rafters - Insulation - DIY Chatroom Home Improvement Forum
Old 04-03-2016, 02:59 PM   #1
Rewards Points: 22
Insulating Cathedral Ceiling w/ 2"x 6" rafters
Looking for advice on insulating the roof of on unattached garage. Garage is 20'X24' with 4/12 asphalt roof; has peak vent and vents at the eaves. I know I need to maintain a minimum of an 1" air gap between the insulation and roof sheathing.
So one option I'm looking at is installing R15 batts which would give me 2" of air flow.
I would like to increase the R value if I could so I was also thinking about installing foam baffles the entire length of the rafter run (from eave vent to peak vent) and installing R19 batts. This would still maintain air flow but the batts would be slightly compressed to sit flush with the rafters. Has anyone ever done this; or see any issues I would run into going this route?
The R19 batts are available in my local area and the R15 batts are not. It's about a 4 hour drive one-way to a big box store that carries R15 batts 23" wide and the price is only $5 a bag less then the local cost of R19 batts 23".
I'm still undecided if I will sheet over the rafters once I install insulation might just run 1" X 2" across the rafters ever 3-4' to help get the insulation from sagging.
wildseamus is offline   Reply With Quote
Old 04-03-2016, 03:32 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 816
Re: Insulating Cathedral Ceiling w/ 2"x 6" rafters
How accessible is the inside?
Full perimeter soffit vents?
What area of the country?
How handy are you?
Old 04-03-2016, 08:40 PM   #3
Rewards Points: 1,854
Why does it have to be a Cathedral ceiling?
If you use faced insulation it will need to be covered with sheetrock to meet code.
Going to be a whole lot harder to heat and cool, tons of lost storage space if you use wide enough rafters, that way you could even go with R-50 if you needed to.
Old 04-03-2016, 08:52 PM   #4
Property Mgt/Maint
Rewards Points: 24
location? R13 might be fine in Miami, but won't work in Boston
Yodaman is offline   Reply With Quote
Old 04-03-2016, 10:30 PM   #5
https://www.energystar.gov/index.cfm...sulation_table
Old 04-03-2016, 10:30 PM   #6
Rewards Points: 22
Location is in NE Oregon; below zero temps in winter and over 100 in summer.
Old 04-03-2016, 11:13 PM   #7
Rewards Points: 22
How handy are you?
Live in NE Oregon, I'm pretty handy and the vents are at every eave (each birdblock is vented) and the peak.
Old 04-03-2016, 11:17 PM   #8
Rewards Points: 22
[QUOTE=joecaption;3174089]Why does it have to be a Cathedral ceiling?
Going to be a whole lot harder to heat and cool, tons of lost storage space if you use wide enough rafters, that way you could even go with R-50 if you needed to.[/QUOT
2" x 6" rafters on 24" centers and it is a cathedral ceiling
Old 04-03-2016, 11:19 PM   #9
Rewards Points: 22
NE Oregon, below zero temps winter and above 100 in summer
Old 04-03-2016, 11:21 PM   #10
jlhaslip's Avatar
Rewards Points: 708
Add to the depth of the afters by nailing 2 x 2's to the bottom of them.
This should allow for the ventilation air space and enough space to install deeper batts.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-03-2016, 11:21 PM   #11
Rewards Points: 22
Location is NE Oregon; below zero temps in winter and above 100 in summer
Old 04-03-2016, 11:30 PM   #12
Rewards Points: 22
I did think of that but there is a loft storage area below the ceiling and adding 2" to the rafters is not an option.
Old 04-03-2016, 11:38 PM   #13
jlhaslip's Avatar
Rewards Points: 708
Also, I just re-read the opening post of the topic.
This is a garage, which nobody will be living in, so the codes for insulation will not apply; so don't be concerned abut meeting the required R-values for insulation. (At least here where I am, the code would not apply.)
Use whichever insulation value you have available; remembering that compressed fibreglas insulation will not be the same effective value. You are likely better off with a full R-12 rather than a compressed R-20 is what I am suggesting.
Old 04-04-2016, 06:40 AM   #14
Property Mgt/Maint
Rewards Points: 24
What will the space be used for? Are you going to heat/coo the space? Irregardless if you are concerned about meeting code, condensation from light insulation is a bigger concern. Especially so in cathedral ceilings.
Old 04-04-2016, 07:13 AM   #15
Rewards Points: 816
Me personally...I would make my own full length vent chutes our of foil faced ISO board, seal up the vent chutes to the edge of the rafters to prevent air communication, fill the remaining cavity with fibrous insulation, cover the fibrous insulation with drywall.
The Following User Says Thank You to Windows on Wash For This Useful Post:
wildseamus (04-04-2016)
Insulating Cathedral Ceiling (area around skylight to be replaced) dcase84 Insulation 5 10-13-2012 07:31 AM
insulating cathedral ceiling South Branch Ca Building & Construction 1 11-06-2011 07:41 AM
Insulating 2x4 attic ceiling rafters help needed tseverson Insulation 2 11-01-2011 07:57 PM
Cathedral ceiling ventilation dpreznik Roofing/Siding 2 10-31-2006 10:18 AM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 11:19 AM
