Insulating Cabin Ceiling - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 03-03-2018, 03:07 PM   #16
Rewards Points: 16
Re: Insulating Cabin ceiling
Originally Posted by Marson View Post
I would skip the ventilation personally. Venting isn't going to help the insulating value; it just provides a way for humidity to vent out of the building instead of condensing on the underside of the sheathing. It also can keep shingles cooler, but that is a non factor here. I would pack those rafter cavities full and and install a good 6 mil poly vapor/air barrier.
If you only use this cabin a few times in the winter, the amount of indoor humidity is really going to be negligible, and thus the chance of condensation in the roof cavity.. With only 2x4's in the lid, you might melt some snow off of the steel roof when you get your wood stove cranking, but that is no big deal.
I built a cabin for myself, and while I have more insulation than you are planning (9" of dense pack cellulose), there is no ventilation whatsoever. Have not seen a problem yet.
Any batt insulation that is better than others with regards to deterring mice?
13moe is offline   Reply With Quote
Old 03-03-2018, 09:29 PM   #17
Rewards Points: 1,360
Sorry, I don't know the answer to that one. Maybe roxul or something would be better? Do you have red squirrels? They will strip the fiberglass clean out of your walls/roof. Might be a good reason to go with rigid foam.
Probably too late for this advice, but when I built my cabin I was very anal retentive about not allowing any gaps in the sheathing, including very tight bird blocking between the rafters.
Marson is offline   Reply With Quote
Lesson on how to give textured ceiling an even painted look stripedbass Drywall & Plaster 1 01-06-2016 10:16 PM
Getting a uniform look to textured ceiling stripedbass Painting 33 11-25-2015 02:05 AM
Insulating 2x4 attic ceiling rafters help needed tseverson Insulation 2 11-01-2011 07:57 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
