Insulating Between Joists Above Basement Windows - Insulation - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 2 Post By NotyeruncleBob
  • 1 Post By jrml
  • 1 Post By Windows on Wash
  • 1 Post By jrml
Old 10-05-2017, 10:07 AM   #1
Rewards Points: 14
Insulating between joists above basement windows
I'm in the process of adding insulation to the basement walls of my 1950's brick house. Right above the windows, there was a strip of metal lath and plaster covering the area shown in the pictures. I plan to do drywall returns but should I try to insulate these spaces somehow?
Any ideas or suggestions are greatly appreciated!
Insulating between joists above basement windows-img_6969_1507215961298.jpg   Insulating between joists above basement windows-img_6967_1507215980849.jpg   Insulating between joists above basement windows-img_6966_1507215991189.jpg
jrml is offline   Reply With Quote
Old 10-05-2017, 11:46 AM   #2
Rewards Points: 1,066
Re: Insulating between joists above basement windows
Yes.
An effective way to insulate the rim joist is what's commonly referred to as "cut and cobble" where you take pieces of EPS foam board insulation that are slightly undersized, place them in there, and then fill the gap around the edge with spray foam to create a seal and hold the EPS in place.
Dave Sal and Nealtw like this.
NotyeruncleBob is offline   Reply With Quote
The Following User Says Thank You to NotyeruncleBob For This Useful Post:
jrml (10-05-2017)
Old 10-05-2017, 12:25 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 904
Cut and cobble with some copious application of canned spray foam should do the trick.
The Following User Says Thank You to Windows on Wash For This Useful Post:
jrml (10-05-2017)
Old 10-05-2017, 12:35 PM   #4
retired framer
Rewards Points: 604
Hmmmm I have never seen steel used as a header like that.
Old 10-05-2017, 03:21 PM   #5
Rewards Points: 14
Done! Thanks!
Nealtw likes this.
Old 10-05-2017, 10:01 PM   #6
Rewards Points: 904
Double lintels.
Nealtw likes this.
Old 10-06-2017, 11:40 AM   #7
jlhaslip's Avatar
Rewards Points: 708
Don't know about the code where you are, but foam needs to be protected with a layer of non-combustible material around here. Drywall and a mud coat of tape works.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-06-2017, 12:33 PM   #8
retired framer
Rewards Points: 604
Strange how they apply that rule out here. Crawlspace and attic not so much
Even when furnace is in crawl space.
Old 10-06-2017, 07:28 PM   #9
Rewards Points: 904
Figured the OP was finishing the basement.
If not, cover it with roxul or other fibrous insulation.
Nealtw likes this.
jrml (10-06-2017)
Old 10-06-2017, 09:00 PM   #10
Rewards Points: 14
I used foam and put drywall up, just need to mud and tape the corners.
Thanks again!
Nealtw likes this.
Insulating row house/townhome basement Poops Insulation 2 12-12-2014 02:23 PM
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 03:41 PM
Finishing Basement - notch in joists? bing16 Building & Construction 5 12-30-2010 12:20 AM
Strengthening Joists Before Basement Finish braverichard Building & Construction 16 06-20-2010 07:28 PM
