Insulating Basement Stairway - Insulation - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By Windows on Wash
Old 11-16-2016, 08:48 PM   #1
Rewards Points: 2,264
Insulating basement stairway
I have a 37 inch wide basement stairway. The one side is the exterior concrete wall. What is the best way to insulate/finish this and still keep the needed 36 inches?
TIA
mae-ling is offline   Reply With Quote
Old 11-16-2016, 09:11 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 856
Re: Insulating basement stairway
If you can't only spare the 1", some 1/2" rigid foam and drywall overtop.
123pugsy and de-nagorg like this.
The Following User Says Thank You to Windows on Wash For This Useful Post:
mae-ling (11-17-2016)
Old 11-18-2016, 04:25 PM   #3
Young Bachelor
CTSNicholas's Avatar
Rewards Points: 481
Why keep the 36" minimum unless you are going under an inspection? I'd argue you can't tell much difference between your 37" and 34.5" (2" Rigid Foam for R-10 + 1/2" Drywall)
CTSNicholas is offline   Reply With Quote
Options for trim on basement stairway? spinnaker15136 Remodeling 8 10-23-2016 07:58 AM
Insulating basement that has thermal-dry wall treatment Trd-joe Insulation 2 02-09-2016 11:22 PM
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Concrete Basement Floor Insulating options McSweny1103 Insulation 7 03-08-2011 05:24 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
