Insulating Basement - Remodel - Insulation - DIY Chatroom Home Improvement Forum
Old 03-11-2016, 08:47 AM   #1
Rewards Points: 96
Insulating basement - remodel
How would you guys insulate this laundry and bathroom area?
Do I need a vapor barrier here?
In the family room I'm going to fluff and add more insulation where needed and then install a vapor barrier. We have added new windows and doors.
Any other suggestions?
isuhunter is offline   Reply With Quote
Old 03-12-2016, 09:34 PM   #2
Rewards Points: 6
Re: Insulating basement - remodel
I didn't do a vapor barrier in my basement. Foam board, studs, rolled insulation and 1/2" drywall. I've been told vapor barriers CAN inhibit mold, too each their own.
Sent from my iPhone
Aaron1085 is offline   Reply With Quote
Old 03-13-2016, 09:53 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Where is the home? You will need to follow code unless you can otherwise show the inspector what you are doing to control moisture migration.
Foam board is a proven and effective insulator here.
Given that the walls are up, SPF is certainly and option as well.
Both (if you select properly) will provide the vapor retarder and insulation layer in one fell swoop.
Insulating Uneven Basement Wall Help (with pics) jefferyscott Building & Construction 3 02-01-2013 11:32 AM
Basement remodel planning - Guidance needed for framing around oddities visim14 Remodeling 4 11-13-2012 11:27 AM
Insulating Daylight Basement Questions Tweak3D Insulation 8 10-06-2012 12:36 PM
Help me choose a layout for my basement remodel (Pictures attached) danreg99 Remodeling 16 08-14-2012 08:51 AM
Insulating basement - questions jtmann HVAC 7 11-19-2010 03:20 AM
